04-26-2006, 12:49 AM | #1 |
blinker prob
what could cause my blinkers when i turn them on they stay on solid and dont flash the same as the hazards the switch is brand new as is the wiring on the column and the column it is a new tilt column if that helps
04-26-2006, 01:03 AM | #2 |
saving one more
Re: blinker prob
Two quick things come to mind. One, make sure you don't have a burned out bulb. When one of my bulbs burns out the light on the dash comes on solid and doesn't flash.
Two, check the flashers under the dash, if all the bulbs are working but not flashing, sounds like the flasher went bad. Hope this helps.
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab |
04-26-2006, 01:10 AM | #3 |
Happy Camper
Re: blinker prob
But you can also check for bad or corroded sockets, and bad grounds at the sockets.
RIP El Jay! Love you brother! |
04-26-2006, 01:51 AM | #4 |
Re: blinker prob
thanks, ya all the lights work so ill check the flashers
04-26-2006, 10:21 AM | #5 |
Re: blinker prob
Orange '71 GMC Last edited by Orange '71 GMC; 04-26-2006 at 10:22 AM. |
04-26-2006, 11:21 AM | #6 |
Re: blinker prob
ummmm blinker fuild what the heck
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-26-2006, 11:41 AM | #7 |
Re: blinker prob
if the lights come on that doesn't mean that BOTH filaments are working 90% you've got bad bulb(s)
04-26-2006, 08:08 PM | #8 |
Re: blinker prob
im pretty sure the bulbs are good cause ya they come on but when i turn the blinker on they get brighter like they are working just not blinking
04-26-2006, 08:25 PM | #9 |
Re: blinker prob
I had this problem when one of the front parking light assemblies wasn't grounded well enough due to corrosion. BTW your username sounds kinda... uh familiar, I thought about changing mine since it sounds gay. Oh well, guess I'm stuck with it!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
Thread Tools | |
Display Modes | |
