Old 04-27-2006, 01:11 PM   #1
76bonanza
76bonanza's Avatar
por-15 question
Can you cover it with like a clear enamal or something or something?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 04-27-2006, 01:53 PM   #2
JRB
JRB's Avatar
Re: por-15 question
I have bought it in different sheens, I use the semi gloss under the hood and where I wont see it and the gloss where I can see it like the differential. One thing you want to remember is when you use it before you close the container put a peice of saran wrap between the opening and the lid. If you dont good luck opening the can the next time you want to use it. Yes I found out the hard way. Good Luck with your project.
JRB
JRB is offline   Reply With Quote
Old 04-27-2006, 03:23 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: por-15 question
You actually HAVE to paint it with a UV safe covering.
It's right on the can.
Old 04-27-2006, 04:23 PM   #4
JRB
JRB's Avatar
Re: por-15 question
After talking with a person at my local paint shop. They told me that you can get POR15 in black, Gray, Silver and clear. They told me you can paint over it with an enamel but you would have to use some sort of an etch base primer if the POR15 is hardened. If it is still wet you can spray an enamel over it. Hope this helps.
JRB
Old 04-27-2006, 04:39 PM   #5
Longhorn Man
Re: por-15 question
You can scuff it and spray paint right on it... we do this all the time at work.
Old 05-01-2006, 08:54 AM   #6
4x4Poet
Re: por-15 question
Good advice. IMO, it's best to topcoat with clear enamel when the POR15 is sticky, but not wet. When it will leave a fingerprint but not stain da finger.
Waiting until the POR15 is sticky reduces the chance of topcoat runs and improves adhesion compared to still wet.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-01-2006, 02:33 PM   #7
BigSky71
LAIDOUT
BigSky71's Avatar
Re: por-15 question
What grit do you suggest for a scuff? Do you think you need to apply multiple coats of POR15 if you plan to top coat it? I have one coat on the bottom of my fixed cab right now, and plan to spray Rustolem enamel on it.
Thanks!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 05-01-2006, 03:10 PM   #8
4x4Poet
Re: por-15 question
Bigsky, if the single coat is clean or cleanable, you don't *need* to scuff it to add another POR15 coat. It sticks to itself. Scuffing a little to add another POR15 coat wouldn't be a bad idea, IMO, but you wouldn't want to scratch through to the metal and ruin the *seal*.
POR15 always recommends two coats, but that may be to sell more POR15. It goes on pretty thick with a brush in my experience. Still, a thick, double coat with good film strength is arguably warranted for the underside of the body that sees gravel strikes.
While the second coat is sticky, spray the Rustoleum to avoid having to use a tie-coat primer.
Old 05-01-2006, 08:26 PM   #9
Solver
Solver's Avatar
Re: por-15 question
If your por15 has already set up there is another option.
Por15 now offers an etch primer instead of the old tie coat (also still available).
The etch primer will go over old (cured) por15 without extra work and can be topcoated with anything
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 05-03-2006, 01:10 PM   #10
BigSky71
LAIDOUT
BigSky71's Avatar
Re: por-15 question
I agree, my one coat I applied with a foam brush is quite thick. I scuffed it the other night with 320, and plan to topcoat it this weekend. Scuffing the entire bottom of the cab and all the contours was no small task I must say, should have just ordered some of the new POR primer! Doing the scuffing I also sanded all my fingerprints off [no kidding], now all surfaces I touch are slippery...
67 2wd Shorty
Build Pictures
Old 05-10-2006, 11:59 PM   #11
bluec10
bluec10's Avatar
Re: por-15 question
I want to respect the people using POR15 - I've used it myself. BUT, I like the Easwood rust encapsulator better. Easier clean-up and it doesn't try to kill you. Just my .02, sorry for going off topic.
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 05-11-2006, 12:10 AM   #12
72armyswbtruck
72armyswbtruck's Avatar
Re: por-15 question
Man, I was a day late and a dollar short, I painted for-15 silver on the frame and didn't put a clear coat over it, now I have a silvery green color, just makes it look like it has a fou (?) finish my neighbor calls it an antique patina
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 05-11-2006, 02:54 AM   #13
Longhorn Man
Re: por-15 question
probably should have read the directions huh?
Old 05-11-2006, 10:13 AM   #14
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: por-15 question
Following the instructions is very important with POR products. Even then, the results can be disappointing. After 8 years, the wheels on my 52 are rusting through the two coats of POR-15 and two coats of their top coat. I'm looking for a better "miracle cure" for rust.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-11-2006, 11:22 AM   #15
d4xycrq
Re: por-15 question
Rust Bullet is a competing product. I'm restoring a tractor and have used it. So far so good.
Ray
d4xycrq is offline   Reply With Quote
Old 05-11-2006, 02:07 PM   #16
Frizzle Fry
Frizzle Fry's Avatar
Re: por-15 question
One word: Galvanize
Frizzle Fry is offline   Reply With Quote
Old 05-11-2006, 06:16 PM   #17
76bonanza
76bonanza's Avatar
Re: por-15 question
those that have used eastwoods encapsulator do the airisol cans work good? how many cans do you think to do the floor pans?
1968 c10
lowered 3" 4"
Old 05-12-2006, 02:44 AM   #18
4x4Poet
Re: por-15 question
Rust Encapsulator aerosol cans work well. I like the product, too.
I'd guess two cans, minimum, to cover floor boards. Three to be well prepared. But I've never tried to cover an entire floorboard with Rust Encapsulator. Did a partial with one can, once.
Old 05-12-2006, 11:07 AM   #19
bluec10
bluec10's Avatar
Re: por-15 question
Don't buy the spray bomb, buy a quart. Cheaper, more, and with a brush you can really work the product into the rusty areas.
My .02.
Present:
Past:
Old 05-14-2006, 03:46 AM   #20
4x4Poet
Re: por-15 question
Bluec10 is right. I should have recommended the same for floorboards that nobody sees and that need every crack and crevice protected. Good call.
Thread Tools
Display Modes
