Old 04-30-2006, 10:24 PM   #1
benoit454
Chris
benoit454's Avatar
Plate between motor mount and block on K10
I have an 86 305 k10 with a 700r4 and just recently pulled the 305 to put in a 350 once rebuilt.
I noticed the 305 mounts had a 1/4in. or so plate between the clamshell moutn and block.
What is this for? They have one on each side, and a bolt hole in back, the are both slightly different though.
Do they need to go back in?
I had a 76 2wd and it didn't have them.
What would happen if you left them out?
I can get pictures tomorrow if anyone needs them.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 05-02-2006, 01:14 PM   #2
60-66 Nut
Professional Beer Tester
Re: Plate between motor mount and block on K10
If I recall correctly, they came with braces which bolted to those plates and to the bell housing, and I think the automatics had a cast alluminum flywheel cover with the braces bolting to it. I doubt that leaving them off would make much difference.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 05-05-2006, 11:09 PM   #3
1976K5CHALET
1976K5CHALET's Avatar
Well...the reason gm did that was they were experiencing a high number of cracked bellhousings on auto 4wd transmissions. By adding the paltes and the strut rods to an aluminum case it stiffened up the problem area. They also started using the t-case rod that went from the t-case to a bellhousing bolt.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 05-07-2006, 03:27 PM   #4
benoit454
Chris
benoit454's Avatar
Yea mine has the transfer case rod but the others and dust cover are long gone.
Chris
GIT R DONE!!!!!!
Thread Tools
Display Modes
