Old 05-01-2006, 08:41 PM   #1
aboyer
Adam B
What is this on my Brake Booster???
Can someone tell me what is the item that is left side of the master cylinder?
(The left side facing in the picture)
I have a 68 Chevy with front disk brakes. There is a prop valve on the opposite side, but I am not sure what this is on the other side.
It doesn't seem orginal equipment, so if anyone can help me out, I would appreciate it.
Adam
aboyer is offline   Reply With Quote
Old 05-01-2006, 08:51 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: What is this on my Brake Booster???
vacuum hose I think
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 05-01-2006, 08:55 PM   #3
truckdude239
truckdude239's Avatar
think he talking about this in the yellow i have no clue other then maybe tailier brake
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-01-2006, 08:55 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That was probably for the old school trailer brake control. Have you folowed the lines?
Old 05-01-2006, 08:59 PM   #5
69face
69face's Avatar
it's a trailer brake or the solenoid for a second emergency brake which is usually used on tow trucks and heavy duty trucks.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 05-01-2006, 10:29 PM   #6
wibilly
wibilly's Avatar
the line looks like it comes from the master cyl then right to the proportioning valve do you suppose it is some kind of external residual valve? the end of the bracket on the mc looks factory but the line appears to be rebent
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-01-2006, 10:45 PM   #7
Solver
Solver's Avatar
My guess would be that because someone added the disk brakes (not available in 68) and they kept the original proportioning valve for drum brakes that this is an equalizing valve for the disks to be proportioned properly.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 05-01-2006, 10:52 PM   #8
rauto13
saving one more
rauto13's Avatar
on my 70 Camaro, there was a setup like that from the factory, I was told it is to equalize the pressure for the front disk vs rear drums. On the Camaro, the "proportioning" valve is just really a distribution block. That is what I was told anyway.
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 05-01-2006, 11:27 PM   #9
stope4
What you think is the proportioning valve must be a distribution block only. The item that is circled is known as a proportioing valve. I thought 67-72 trucks only used one piece combination proportioing/distribution blocks.
stope4 is offline   Reply With Quote
Old 05-01-2006, 11:58 PM   #10
Livrat
Member #1049
Livrat's Avatar
The block with the all the brake lines going into it is the distribution block.. which is factory for the drum brakes.. the one you are asking about is a "porportioning valve" for a disc brake setup.. it looks like a factory GM on off of a 68 - 70 Chevelle,Camaro,Nova
One thing I noticed is your master cylinder is a drum brake unit and will not function correctly with disc brakes as it does not have an internal "residual pressure valve" that the disc brakes require.. it keeps a small amount of pressure on the calipers... you may find that you will always have to pump the brakes to get a good pedal..
That setup could/may be dangerous!!.. The porportioning valve may not be calibrated correctly for the larger truck rear wheel cylinders and brake size..(a porportioning valve limits the fluid pressure to the rear wheel cylinders) plus the master cylinder might not have the correct piston diameter to put the correct pressure to the disc brake calipers.. (disc brake calipers take different pressure to engage than the original drum brake wheel cylinders)
In my opinion I would get the correct 71 - 72 truck disc brake booster, master cylinder, combination distribution/porportioning valve and lines that way you KNOW it will work like it should..
Livrat is offline   Reply With Quote
Old 05-02-2006, 06:10 AM   #11
70GMCer
70GMCer's Avatar
I had the same thing on my 67 Chevelle w/disks
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-02-2006, 01:36 PM   #12
Bob Moore
I agree with LIVERAT and 70GMCer. The Camaro,Chevelle, and Corvette people would probably pay a good penny for that piece. I have not seen one in the junkyards for a loooonnnngggg time. Listen to LIVERAT and get the proper parts and sell that piece to partially offset the price of safety.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 05-02-2006, 10:57 PM   #13
aboyer
Adam B
Thanks for the tips. I am planning on switching the rear drums to disk, in the coming months. Maybe someone could help me out with this, but I was planning on purchasing a new brake booster/master cylinder 71-72, then I would also need a new prop valve for the rear disk brakes.
I believe this is correct, but want to make sure. Let me know if this sounds good.
Adam
Old 05-03-2006, 08:38 PM   #14
72armyswbtruck
72armyswbtruck's Avatar
WOW, you learn something new everyday...
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Thread Tools
Display Modes
