Old 05-02-2006, 07:34 PM   #1
mrgoodwrench_420
Talking where do i put the wires
i just swaped out the 6 for a 8 how do i make the 6cyl wires go into the hei on my 8 what wire goes where
mrgoodwrench_420 is offline   Reply With Quote
Old 05-02-2006, 07:43 PM   #2
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
Re: where do i put the wires
Be more specific, plug wires? Start/Ignition switch wires? If you are reffering to the hot wire for the HEI you will have to make a new one that is from a keyed 12v source. The starter wire(s) should be the same, but you will just use the one to the solenoid since you are no longer running points.
"The bigger you are the harder you fall, the farther you walk the longer you crawl."
farmtruckIII is offline   Reply With Quote
Old 05-03-2006, 08:35 PM   #3
72armyswbtruck
72armyswbtruck's Avatar
Check the FAQ's there was a post of a colored wiring diagram, I don;t know them off the top of my head. Hope you get it running
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Thread Tools
Display Modes
