Old 05-03-2006, 08:49 PM   #1
76bonanza
76bonanza's Avatar
hood springs
Is there an easy way to remove the hood springs with out removing the hinges? Got some used springs off a guy and want to see if they work better than mine but dont really want to undo the hinges.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 05-03-2006, 10:26 PM   #2
extd56
extd56's Avatar
Re: hood springs
Have a friend hold the hood open and use a screwdriver to take the springs off.
extd56 is offline   Reply With Quote
Old 05-03-2006, 11:18 PM   #3
69-350
Oil trash and damn proud of it
69-350's Avatar
Re: hood springs
I don't think I ever had problems just manhandling mine off by myself... or putting a hood hinge on by myself (although a perfectly sized 2x6 helped a lot)
so if I remember right, just try to grab the main part of the spring, and wiggle it around and wiggle it off (it might help or not to move the hood around to try and get that "perfect" angle)
Mark
1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift
1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze
2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons
Some of my pics http://s107.photobucket.com/albums/m294/69-350/
69-350 is offline   Reply With Quote
Old 05-03-2006, 11:30 PM   #4
kwmech
Re: hood springs
I prop up the hood, grab the springs and pull.
kwmech is online now   Reply With Quote
Old 05-03-2006, 11:54 PM   #5
purple gas
Re: hood springs
I think I used a piece of small ( 1/4" ) nylon rope looped around the hook part of the spring. The other part of the rope I wrapped around a piece of broom handle or dowel or something. The piece of wood gives you a good handle to pull with and keep your hands away from the spring. Springs scare the hell out of me. They move fast and can pinch like a nasty little girl.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 05-04-2006, 08:24 AM   #6
Putter
More Cowbell....
Putter's Avatar
Re: hood springs
Here is what I did....I grabbed a crowbar out of the shed (stay with me here). On my crowbar, there is a flat end and a hoked end. The flat end has a teardrop-shaped cutout for grabbing nailheads. The hook of my springs fits into that cutout perfectly....leaving the hooked end of the crowbar available for me to grab onto and pull. Lots less force needed if you can stand in front of the grill and not have to sit on the radiator!!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-04-2006, 08:36 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Re: hood springs
I've done this once. I used a good pair of vice grips, while the hood was up (and propped with a broom) I put the grip on the front hook thing and pulled and it came right off. The pain in the arse is putting it back on. I shoved a couple large screwdrivers between the coils so it was easier to get it back on using the vice grip method
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-04-2006, 09:11 AM   #8
cdowns
cdowns's Avatar
Re: hood springs
just try to outthink the spring
Old 05-04-2006, 11:10 AM   #9
redhead69
fugedaboutit
redhead69's Avatar
Re: hood springs
I use a rag or towel apx 8"x12".. center it on the front hook and use it as handles ..have a friend hold the hood open and pull like hell. Also works great for re-install. You might pinch part of the rag in there but thats easier to get out than your finger.. and also wont scratch yur paint
Currently truckless
redhead69 is offline   Reply With Quote
Thread Tools
Display Modes
