Old 05-03-2006, 10:09 PM   #1
raidermanny
raidermanny's Avatar
40 series or super 40 flows
I am getting ready to get my exhaust done and can't decide between the flowmaster 40 or super 40 series. I was talking to a flowmaster rep at the last good guys show and he said there is no difference in performance between the two, just sound, even though the website says different. Has anyone heard the super 40's? So far those are the ones I'm leaning towards. The flowmaster website has a sound clip for both but they are on two different motors so it's hard to tell. Any advice, suggestions are appreciated. This is going on a 450 horse 383 with Hooker super comp headers.
raidermanny is offline   Reply With Quote
Old 05-03-2006, 10:15 PM   #2
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: 40 series or super 40 flows
Are you going to run 2.5 or 3" exhaust? That will make it sound different as well. Depends on the sound volume in the cab that you want, too. I have listened to the sound clips as well. They all sound a lot alike. I would go with the loudest with the best flow myself. I think they were the Super 40's, That's what I will install on my 66 Chevelle with 3" pipe.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 05-03-2006, 10:28 PM   #3
raidermanny
I was thinking I would run 3" into the mufflers and then 2 1/2" after and dump behind the rear end but will seek advice on that too. I think the super 40's sound the best on the sound clips.
Old 05-03-2006, 10:44 PM   #4
QKENUF4U
QKENUF4U's Avatar
Thumbs up Re: 40 series or super 40 flows
i just picked up a set of SERIES 40's for my truck. they will be put on this weekend. from what ive been told/read they resonate at 1800-2500 and then again at like 3800-4200rpm (somthing like that ) my truck has 3:08 gears and cruises along at 1200rpm or so , so im not worried about the resonance.
from what ive read, you need to run what the motor needs BEFORE THE MUFFLER and then you can run whatever you want afterwards. ya have to remember your setting the backpressure with the pipe size BEFORE the muffler and just expelling gases afterwards. im gonna run 2 1/2 from the header to the muffler and then 3" out the back behind the wheel. cant wait to hear my BB w/ the flows.
QKENUF4U is offline   Reply With Quote
Old 05-03-2006, 10:56 PM   #5
71chevytruckguy
71chevytruckguy's Avatar
from what i've heard the super 40's are little quitter and desinged for big blocks. i have regular 40's with headers and 2 1/4" pipe one my '69. its a little quite for my taste but still sounds good. there's bad resonance from 1000 to about 1500 if i ur just crusin, but when ur on it, you don't hear it. i cruise along at about 2000+ no matter what gear im in and there's none there.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 05-04-2006, 12:14 AM   #6
QKENUF4U
QKENUF4U's Avatar
Unhappy Re: 40 series or super 40 flows
great that prob. means mine is gonna resonate like crazy then.
Thread Tools
Display Modes
