Old 05-04-2006, 10:20 PM   #1
71swb4x4
71swb4x4's Avatar
Can I remove my rear coil spring upper mount?
I am getting ready to put my rear bags in. I am using Slam Specialties RS-72's. The upper bolt holes are 2 3/4" apart, which means that the inner hole will be off the frame sitting in the little cup part of the upper bracket. This is going to make it nearly impossible for me to put that bolt in, since the body is still on. What I want to do is remove this piece, and install a plate that would basically make the frame a little wider right here, giving me extra material to mount the bag to, while making it easier to install the bag. At least 90% of the bag will still be resting on the main part of the frame. I feel very comfortable using this as a solution but I wanted some outside input too.
What do you think?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-04-2006, 11:58 PM   #2
smbrouss70
smbrouss70's Avatar
Re: Can I remove my rear coil spring upper mount?
I'm thinking that if you remove that bracket coming off of the crossmember, you might have some issues with the lower portion of the frame rail wanting to "roll" inward once you have the weight of your Jimmy back on it. If you think about it all of the weight that the rear bags will be supporting will be resting in these exact spots. If you remove it you really "should" box in that area of the frame, which would make it completely impossible to put the bolts in that hold the top of the bag in place.
My best solution for you would be to rotate the bag to where the two bolt holes would be forward and aft of the center hole (the original hole for the coil spring bolt). This in turn would make it a little easier to put the bolts in because you wouldn't have to reach "inside" of the bracket as far, and the bolts would be going through the actual frame also.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-05-2006, 12:20 AM   #3
smbrouss70
smbrouss70's Avatar
Nevermind, I just looked online at a pic of the top of your bag, and my "solution" would make it a pain in the a@@ to get the airline fitting in because it would be pushed to the outside of the frame or inside of that bracket.
According to MrShelley's Illustrated Air Bag Installation Guide you should be able to drill the holes inside and out of the original hole, unless the Slam bags have a different bolt configuration than the Airlift bags he used.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Thread Tools
Display Modes
