05-07-2006, 09:38 AM | #1 | |||
Union Electrician
Frame damage?
I was cleaning up my truck a little this weekend and am having an issue with the starter and need to replace it. While I was under the truck to tap on the starter to get it in the garage I noticed what looks to be a bent frame???? I have two pics of the spot in question and it looks as the frame starts to go down and under the cab it is tweeked a little Am I looking at it correctly and am I right? I didn't see the same tweeks on the DS and I figure it has been hit pretty good to say the least. Just looking for some verification if it is indeed bent and how/if it can be fixed. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
05-07-2006, 02:11 PM | #2 |
Re: Frame damage?
dont know heres a ttt for you
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-07-2006, 02:34 PM | #3 |
Re: Frame damage?
Hard to tell without seeing it in person ttt
Shane YeeHaw post#502
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
05-07-2006, 02:46 PM | #4 |
Re: Frame damage?
i see no bends... take pics /w/ a ruler next to it... or something to set off the size and depth...
05-07-2006, 04:13 PM | #5 |
Re: Frame damage?
Does not appear that the frame is damaged. What is leading you to think so?
05-07-2006, 04:40 PM | #6 |
Re: Frame damage?
can you get some measurements from WITHIN the frame? inside metal-to-metal...
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd |
05-07-2006, 05:42 PM | #7 | |||
Union Electrician
Re: Frame damage?
Here is a couple of different shots of it, the spot is kinda dimpled on the bottom. I have tried to outline it in the pics, as the striaght edge pics wouuld come out to see it. It looks as if it has been hit in the front and both sides have been pulled on. Both the DS and PS frame rail have the dimples on the bottom side of the rail in the same spot.(close enough) I hope these pics help to see it better. Thanks for the help!! Randy
05-07-2006, 06:53 PM | #8 |
Re: Frame damage?
Looks pretty normal to me, but still hard to tell. Is the frame cracked anywhere? Is there damage on the frame horns to show possibility of front end crash?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-07-2006, 07:34 PM | #9 | |||
Union Electrician
Re: Frame damage?
Never checked the horns,just noticed this yesterdayand I have owned this truck since late 03', but there is plenty of bondo in the pass fender and the front ps corner of the hood
05-07-2006, 08:30 PM | #10 |
Re: Frame damage?
it's possible that it could be tweaked a little but i highly doubt it. all of the frames i have ever seen for these trucks have wavy spots on the the frame rails. call it bad stamping or GM being cheap, either way it's not worth your time to fix it unless your building a show truck.
ondrew |
05-07-2006, 08:34 PM | #11 |
Re: Frame damage?
I agree
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
05-07-2006, 09:48 PM | #12 |
Re: Frame damage?
Did that have a manual trans at one time ? That looks like about the spot where it would have been riveted in, maybe some not so careful crossmember removal ?? Just a thought.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-07-2006, 10:24 PM | #13 | |||
Union Electrician
Re: Frame damage?
Green machine, yes it was, the PO converted it b-4 I got it. That is probably what happened. Thanks guys for all the help!!! Randy
05-07-2006, 11:51 PM | #14 |
Re: Frame damage?
Just park on a level shop floor and take measurements on both sides, if you have same rubber and inflation all around measurements should be close on both sides, you could also compare to anouther truck of same vintage.
2013 avalanche 5.3l 1971 Gmc 350 1958 Gmc fleetside |
Thread Tools | |
Display Modes | |
