Old 05-11-2006, 12:44 AM   #1
gotmud
gotmud's Avatar
Question Can anyone help identifying frontend donor
I bought this 64C10 partially done from an estate. Working on redoing it but I cant figure out where the frontend donor came from to aid in replacing some of the components? Anyone have a clue where it came from or what the donor was? Could it be stock? Its 5 lugs and disk brakes. Any suggestions on how to buy brake pads etc for it if I cant figure out where it came from?
More pics at:
http://www.whitehorsetechnologies.co...frontendid.htm
Thanks in advance folks!
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 05-11-2006, 12:51 AM   #2
68haywagon
I'm watching you!
Re: Can anyone help identifying frontend donor
Since it has rubber bushings on the control arm shafts I'm going say 73-87 c10. I'm not sure if there are any differences between those years.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 05-11-2006, 12:19 PM   #3
gotmud
gotmud's Avatar
Are there any identifying marks or numbers etc I can check to validate what it came from.
I know its gonna be a pain each time I need to replace a rotor, pad, hose, etc to have to get the 17 year old at the parts counter give me the painful experience of trying to get help.....
Glenn
Cumming, Ga
Old 05-11-2006, 01:04 PM   #4
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
That front end is typical 73-87. The first blue circle in the pic below shows where a new hole had to be drilled in the crossmember for the bolt to line up, and the second blue circle shows where the brake hose connects to the hard line inside the frame (that didn't occur in 64 and I believe it didn't appear until 73, but I might be wrong).
I think Mike is right, just order parts for a 73-87.
You might have been able to positively identify it if the little metal tag was still there (usually on the idler arm or one of the tie-rods) but those things get removed pretty quickly-especially for a paint job.
There were no major differences that I can recall in the c-10 components, so it shouldn't matter. I'd start by just telling the 17 year old you need brake pads for a 77 and then compare them.
Hope I helped some,
Chris
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Thread Tools
Display Modes
