Old 05-11-2006, 03:29 AM   #1
nathan_454
pic request - stipped seat fram
I stripped my seat down to the frame today, And i knew it was bad, but not this bad... I know there is a cross bar that runs across the back of the bottom of the seat... because mine was there. but it just fell out as i was taking the foam out.
IT was all bent and mangled... I need a pic of where the bracket attaches too, so i can make a new one and weld it in... thank you!
nathan_454 is offline   Reply With Quote
Old 05-11-2006, 03:11 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: pic request - stipped seat fram
Here are a few shot's of when I was rebuilding my buckets.
Bare frame.
Frame had been bent and repaired in the past.
I added an extra support rod in the back welded up the cracks and made new sheet metal skirts to replace the bent and broken ones.
Made some attachment points for the seat covers and tacked them in place.
Then to help prevent the seat back from being ben tbackwards again I added two 1x1/4" flat steel to each corner of the seat.
Then got the frames powder coated and recovered them with the old foam.
ALL the pic's of the bucket rebuild can be seen HERE
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-11-2006, 03:30 PM   #3
carrzy4
Active Member
carrzy4's Avatar
wow. looks good.
S.h.i.t happens when you party naked.
carrzy4 is offline   Reply With Quote
Old 05-11-2006, 04:35 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Sweeeeeeeeeeeeeet, FAQ's section material, JMHO
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-11-2006, 05:04 PM   #5
RunTMCfan
RunTMCfan's Avatar
Great work.
On ebay they have powder coating spray guns. Can I spray a powder coat myself at home instead of paint?
Rob
"RunTMCfan"
RunTMCfan is offline   Reply With Quote
Old 05-11-2006, 07:27 PM   #6
krue
Designated A-hole!
krue's Avatar
Yes, it's not too hard.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 05-11-2006, 10:46 PM   #7
nathan_454
that is EXACTLY what I wanted!... thank you so much!!!!!
Old 05-12-2006, 12:56 AM   #8
71jimmy
71jimmy's Avatar
You'll need an oven to bake/cure the powder coating.
For some reason my wife has a problem with my car stuff in the oven with the Thanksgiving Turkey.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 05-12-2006, 03:29 PM   #9
nathan_454
heres another question, can i cut down springs from a bench to work with the buckets? all of them were broken on mine.
Old 05-14-2006, 03:48 PM   #10
BobbyK
BobbyK's Avatar
I never thought of that...but I don't see why that wouldn't work.
Old 05-14-2006, 08:25 PM   #11
nathan_454
im picking up a bench next week. ill see how it works out.
Thread Tools
Display Modes
