05-15-2006, 11:34 PM | #1 |
Coil spring question ?
I replaced the front coil springs on my 1977 1/2 ton . It is way too high in the front now . I thought about buying some 1 inch drop springs to get the height I want . Has anyone replaced their springs and do you have pics /part numbers ? I do not like the heavy duty springs I have . I also need to replace the rear leaf spring packs . Where is the best place to get new ones ? My truck had the lean to the passenger side that they get with only one gas tank . I would like it to sit the same from side to side and have a little rake to the front . Thanks . Frank
Born and proudly residing in a Red State ! |
05-16-2006, 02:28 PM | #2 |
Re: Coil spring question ?
you might try the regular non HD coils... you arent the only one who has had this problem....
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
05-16-2006, 02:49 PM | #3 |
Until Seventy Times Seven
Like Jon said, many experience the same issue when replacing the front coils. I guess over time the stock spring becomes a drop coil spring. If you went with a HD spring, maybe a non-HD would give you the height that you're after. I haven't heard of anyone using 1" drop springs on a stock spindle. I'm not sure if it would give you too much rake?
Eaton Springs (http://www.eatonsprings.com)is a reputable spring manufacturer. I believe they carry springs for these trucks. Maybe, give them a call and see what they suggest.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
05-16-2006, 04:17 PM | #4 |
Hey f.monroe. Here is a link to the coils on our website. They are on sale until the end of May. Good luck with your project.
http://brothersonlinestore.com/prodi...number=LCSE48F
1967 Chevy Short/Fleet 1969 Chevy Short/Step 2004.5 Dodge 2500 4x4 Cummins 6spd |
05-22-2006, 12:10 PM | #5 |
Insert Witty Text Here
I replaced my springs with the HD (store did not tell me they were HD) versions and it looked like a 4X4. The same store was able to order me the regular ones, which dropped it down some. I have the MOOG part numbers at home, and they were the same as a few other brands used. PM me if you want the part number.
Slonaker |
05-22-2006, 10:35 PM | #6 |
Thanks for the info . I bought another pair but this time I bought the lighter duty springs . I hope it comes down between 1 and 2 inches . I got them at Autozone for less than $80 and they were in stock . I hope to get them in this weekend . I will also try to get the back level . I might even try to post some pics . Frank
05-23-2006, 02:21 PM | #7 |
Hey f.monroe,
Please include some pics of that "lean" you're talking about. I'd like to see if it's the same thing I've got. Thanks alot! Jim |
05-23-2006, 11:30 PM | #8 |
The lean is mostly gone now since I added the new coils . It was about 1 inch lower on the passenger side , front and rear. I am sure it is because my truck is a single tank truck and did not have a sway bar from the factory . I dont have any pics of it before . Frank
Thread Tools | |
Display Modes | |
