Old 05-16-2006, 01:21 PM   #1
MEANGREEN70
MEANGREEN70's Avatar
Lower Arms Help
Need help with lower arms. Iam working on a 70 short bed, my question is. Is the lower arms and mounting shaft off a 73 truck the same as off a 70 truck. the reasom iam asking is because I have someone local that has 73 djm arms from sale . i thank you'll for any help that I can get.
MEANGREEN70 is offline   Reply With Quote
Old 05-16-2006, 02:15 PM   #2
SCOTI
SCOTI's Avatar
Re: Lower Arms Help
The bushings are different. The 67-72's used solid, rubber lined 'bushings' & 73-ups use the 'car style' rubbers bushings. Also, because they came standard w/discs, the later arms use larger diameter u-bolts to secure the lower a-arm shaft to the crossmember. There's slight differences w/the bumpstops too,
Differences aside, they will interchange.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-16-2006, 05:33 PM   #3
MEANGREEN70
Re: Lower Arms Help
Scoti, so do you kwon if I can use the 73 truck arms with the 70 truck shaft?
Old 05-16-2006, 10:28 PM   #4
qksilver
Re: Lower Arms Help
no....
qksilver is offline   Reply With Quote
Thread Tools
Display Modes
