Old 05-19-2006, 09:19 PM   #1
ronr
a/c question
Recently bought 72 swb w/ 350. It was a stock air truck. Person I bought it from installed a new sanden compressor and hooked it into stock system. When I got it everything was hooked up. I have brought it to two places they both applied vacuum to it added oil and freon, one changed the pos and expansion valve. Dryer is clear. Lines get cold but nothing inside truck. Any thing missing in one of these conversions , it is converted to new freon.... Thanks
ronr is offline   Reply With Quote
Old 05-19-2006, 09:30 PM   #2
JimKshortstep4x4
Re: a/c question
Does it have the stock dash control and does the flapper valve work when the control is turned to inside?
Also, does the vacuum valve work on the heater hose to shut off the flow when the AC is on?
Jim
Old 05-20-2006, 02:27 AM   #3
ronr
Re: a/c question
Jim
Has stock controls, we put a new vacuum controlled heater hose valve on that works, not sure about flapper valve, where is that located..?
Old 05-20-2006, 06:28 AM   #4
JimKshortstep4x4
Re: a/c question
The flapper door is located on the passenger side under the cowl screen. Here is a picture of the vacuum operator as connected to the door and the door itself.
Jim
Old 05-20-2006, 07:03 AM   #5
JMac11
JMac11's Avatar
Re: a/c question
about 1/2 way through this same project...... Check your diverter flap inside the truck also, probably just uhook all duct work and clea and check for good measure.
Jim.... GREAT Photos.....
JMac11 is offline   Reply With Quote
Thread Tools
Display Modes
