05-22-2006, 06:23 AM | #1 |
Active Member
Rear brake upgrade cheap
Just upgraded the rear brakes on my truck and thought info would be usefull to others.
Backing plates 1981 GMC 2wd 11x2 3/4 w/wheel cyls: free New shoes 1981 GMC 2wd (JB5 brake sys): 39.98 Advance Hardware kit: 6.38 Advance Rear drums 1981 GMC 4wd (six lug): 29.97 (60.00) Autozone #8846 Just did my brake a year ago and was never really happy with them, last month the axle seal started leaking which really caused problems and knew there had to be a better way other than spending hundreds of dollars for an upgrade kit with 5 lug axles. I am running 15" steel toyota rims, don't think stock rims will clear.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
05-22-2006, 07:16 AM | #2 |
67-72 Addict!
Re: Rear brake upgrade cheap
Thanks for the info.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-23-2006, 11:47 PM | #3 |
A little east of nowhere
Interesting, I wonder if something similar can be done to the fronts?
68 C10 250 4spd 69 C20 327 4spd 69 910 250 3spd 80 K10 350 4spd 76 C60 366 5spd school bus "THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR" |
Thread Tools | |
Display Modes | |
