Old 05-22-2006, 09:25 PM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
wtb eaton ho52 gears
i need a set of spider gears for a 71 eaton ho52.
may be interested in a center chunk or whole rearend if real close to martinsville va so i could pick it up.
or does anybody what 14bolt would bolt right up thanks
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 05-22-2006, 11:01 PM   #2
pumpkin
pumpkin's Avatar
Re: wtb eaton ho52 gears
The full floater 14 bolt spider gears will bolt into the eaton, you just need to change to the 14 bolt axles. I do have lotsa spare parts, just too far away.
pumpkin is offline   Reply With Quote
Old 05-23-2006, 10:07 PM   #3
72shadetree
KEEP ON TRUCKING
thanks would you happen to have just the spider gears shipping shouldnt be to bad on them
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 05-24-2006, 04:00 PM   #4
bisquik65
bisquik65's Avatar
I have a set of 4.56 gears here. thats all i have for now. Bakersville NC
bisquik65 is offline   Reply With Quote
Old 05-24-2006, 10:36 PM   #5
72shadetree
KEEP ON TRUCKING
just the ring/pinion or do you have the spider gears
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 05-24-2006, 11:13 PM   #6
fast_dev
fast_dev's Avatar
i have a 71 3/4 2wd that im parting, would this be correct for you? im not that familiar with the 3/4 tons. im in Ringtown Pa. Thanks, Devin
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 05-24-2006, 11:38 PM   #7
pumpkin
pumpkin's Avatar
I will have some available once I save up for the detroit. I'll post something when I get it, then we can find out about shipping.
Old 05-25-2006, 11:37 AM   #8
drink2mny
drink2mny's Avatar
I tell ya what i'll do.... If you haven't been handled yet..
I have some used ones in good condition..
I'll send them to your house for $30.00
I can get you pics but would be a day..
You can ask others.. I can be trusted..
Support The Board
drink2mny is offline   Reply With Quote
Old 05-25-2006, 03:36 PM   #9
72shadetree
KEEP ON TRUCKING
you have a pm
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 05-25-2006, 10:28 PM   #10
drink2mny
drink2mny's Avatar
right back at ya
Support The Board
Old 05-26-2006, 08:27 AM   #11
EFI70Blazer
Active Member
EFI70Blazer's Avatar
If you do eventually upgrade to a 14 bolt full floater, 1 ton single wheel rear ends bolt right in without having to modify the perches. The 3/4 ton 14 bolts have wider spacing and have to be moved.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Thread Tools
Display Modes
