Old 05-29-2006, 10:22 AM   #1
Madbomber88
Active Member
Madbomber88's Avatar
HEI Conversion, need opinions
I'm going to convert my stock 72 K20 350/SM465 to HEI next weekend.
I just picked up a factory GM HEI distributor on ebay out of a 76 for $14.00.
http://cgi.ebay.com/ebaymotors/ws/eB...BSAA%3AUS%3A11
Now I need an HEI rebuild/tune up kit. There are three that I am looking at... The MSD Ultimate http://www.jegs.com/webapp/wcs/store...tegoryId=11579
Moroso super HEI
Or Pertronix Flamethrower
What's the best bang for the buck? Soon to follow are a new carb, intake, cam, and headers.
Thanks!
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 05-29-2006, 10:29 AM   #2
JRB
JRB's Avatar
Re: HEI Conversion, need opinions
MSD is the way I would go. I have friends that have used them and I have never heard them say a bad thing about them.
JRB
JRB is offline   Reply With Quote
Old 05-29-2006, 11:04 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Why not run it stock? A new module (gm part, no cheap parts store junk) and a new coil, and you'll be set. If you engine is stock, mild, or even in the medium performance range, you won't need, nor notice the extra money you'll be spending. (onless you hit the engine with spray, then you may want the upgraded stuff)
Old 05-29-2006, 11:25 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: HEI Conversion, need opinions
^^ x2 My stock HEI has been fine for many years in my basically stock engine...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-29-2006, 11:33 AM   #5
cdowns
cdowns's Avatar
i'd say go for the moroso with the plug wires and all for $100 bucks looks to be the better deal
Old 05-29-2006, 11:39 AM   #6
barepaint
barepaint's Avatar
I got a procomp. on ebay...brand new...billet...very happy with it
barepaint is offline   Reply With Quote
Old 05-29-2006, 01:36 PM   #7
Green Machine
Green Machine's Avatar
I would just replace what looks bad and try it. Remove the shaft and clean and lube everthing. Remove the old hard grease in the top bushing and carefull repack with high temp grease, its hard to get all the air out. I always replace the pickup coil while in there, ususally the insulation will be going bad or the magnet may be cracked, not alway needed, but you can replace ever other part in there without taking it apart. Add an adjusable vac advance and get a set of springs to tailor the advance. Coil and module usually work , easy to replace later if they don't. Be sure to put some new special heat conducting grease under the module so it does not burn up. Maybe a rotor win't hurt either. Short version - keep it stock and try it.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-29-2006, 05:53 PM   #8
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I have a mallory billet hei dizzy that i got from summit. Haven't had any issues with it.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 05-29-2006, 06:19 PM   #9
barepaint
barepaint's Avatar
ebay man...it was like 78 bucks with shipping...coil everything...hotwire to dist...hook direct to my tac...rocks
Old 05-29-2006, 10:14 PM   #10
71chevytruckguy
71chevytruckguy's Avatar
i've got on of these hei's i got on ebay. its been on for a month and no problem. got a set of accel 300+ plug wires to go with it. dizzy comes with a 3yr warranty. chris.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWN%3AIT&rd=1
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 05-29-2006, 10:26 PM   #11
jhow66
jhow66's Avatar
Here is a good article on HEI rebuild and hop up:
http://www.rustpuppy.org/ignition2/Ignition%202b.htm
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-29-2006, 10:30 PM   #12
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I'd toss a cuve kit,adjustable vac advance,cap and rotor in there,and drop it in.The HEI is a good unit in a fairly stock app.No reason to buy stuff you don't need.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 05-29-2006, 11:06 PM   #13
kelsfine69
18 Till I Die
kelsfine69's Avatar
I had a stock HEI with a Accel super coil on top and curved, but it was rebuilt and all my frieds said "junk". So peer presure set in and I bought a Pertronics Flamethrower complete distributor. Nice and New. Just drop it in and hook it up. Wont have to worry about rebuilding for a long time. They are complety new, housing and everything. And they are not that much $$$, but I dont know what kind of engine you are running or how handy you are at rebuilding dist. M2C
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-29-2006, 11:32 PM   #14
Longhorn Man
Originally Posted by kelsfine69
I had a stock HEI with a Accel super coil on top and curved, but it was rebuilt and all my frieds said "junk"...
So was it junk... or did it in fact work fine?
Hotter coils don't really do much onless you need them... and 90% of the trucks on this board DON'T need anything hotter than a stock HEI.
Old 05-29-2006, 11:38 PM   #15
jhow66
jhow66's Avatar
Now remember what I said about joining you.
Thread Tools
Display Modes
