Active Member
Off-Topic?? - Car Trailers
I don't know if this is off-topic, but I figured I'd get the most views in this group. Mods...please feel free to move if necessary.
I am looking into buying/building a car trailer. A buddy want's to go halves with me and share it. He wants to get together and build it. I thought I've heard you can buy one cheaper. Just wanted to ask what kinds of things I should look for when shopping for one, or for parts for one. I've heard rumors that some don't have enough tie downs points, tube is better than channel, tilt-back vs dove tail. Any info would be greatly appreciated
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
Re: Off-Topic?? - Car Trailers
Yes usually you can buy one cheaper than making one, I know a welder that is building his own, has the supplies and now wishes he would have just bought because it would have been cheaper, and he has no time. H&H makes some really nice tilt trailers, check out thier web site. If you are going to be pulling a show truck, price out an enclosed trailer. I know people that have damaged their paint and windows with open trailers on the way to shows. I trailer my truck to the drag strip in an enclosed, I was looking at open ones when a buddy asked about going half on an enclosed, would never use a open now. Downfall of enclosed is the price.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
Depending on the state laws building might be out of the question. I went with a "BIG TEX" 70ch, 7000lb/16'/ 2 axles with brakes on both/ramps included. If I were going to do it over again I would go with a higher GVW like 9000lb and maybe 18'-20'. On mine if you load a 3/4 or 1 ton you are at the max GVW. I would also get a winch to load non-running vehicles. Mine is flat so when I load a small car I have to unhitch the trailer and jack the front all the way up to take the angle off the ramp-trailer. Beavertail/drop tail/dove tail depending on what you are loading might not help much as you now have 2 angles to get it over.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
Active Member
I definately want a winch on it, but it will be an upgrade. I think I'll suffer a couple times to help justify one. I don't want a trailer for takin cars to shows, so and enclosed isn't what I need, although they are nice. I want it for taking non-running cars/trucks home, or to body shops, or if my 96 chrysler breaks down...again...I can go get it with my 40 year old truck. And then for general use like home improvement, equipment rental, and haulin quads and stuff to the sand.
I was worried about loading. I have a 72 chevelle that I want to drop. But I hope to bag it so maybe I can get the clearance like that. Will a dove tail help with that? Thanks for the feedback guys
If you look around you can probably find a used 16-18' flat bed that is 7,000 capable (you don't want the lightweight landscaping trailers). A key area is the width between the fenders or wheels as trucks especially 4x4 require 82" wide with a 102" max width. I sold one to board member Byrd for $1,000 that had a solid white oak floor. I upgraded to an aluminum 18' dove tail. It weighs about 1500 lbs empty and will handle an extended 4x4 truck with no problem. Bought it for $3,500. and I get 17+mpg towing empty--- it has torison axles, dual brakes, etc. etc.
![]() Join Date: Apr 2000
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
New Member
I had one built with dropped axles instead of the dovetail . Actually its the second one with dropped axles, dealer thought I was crazy but it is a dream to tow and is real easy to winch stuff onto . I also held out for the 102 width which took a little longer to get axles for ,but its nice to be able to open car door rather than to have to crawl out a window . Check your state regs on the 102 width though . Ivan
The LuvShack Garage
As it's already been said, be sure to measure the width 1st
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Trailer brakes are a must.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Happy to be here
![]() Join Date: Mar 2000
If your talking about an open bumper pull, go with nothing less than 18'. If you want a tool box up front get a 21'. Anything shorter will be a pain to load a long bed truck on.
Make sure it's dove tail with slide out ramps to accommodate cars or trucks that are low. You will definitely want tandem axle with electric brakes on one axle. My personal preference is a Bulldog brand hitch.
67 is sold
Just a thought, splitting items like trailers, boats, etc usually does not work out will with friends.
Moved to General ![]() |
#12 | |
Weekend Warrior
![]() ![]() It almost never works out. Your better off buying the trailer and letting him "Rent" it from you each time he takes it untill half of the purchase price is met or whatever agreement you want to have. Who will it be registered and insured with???? I wouldn't even recommend it with a Family member Check your local "Swapper" News there are usually good deals on used car trailers if you are willing to wait a few weeks or month or whatever. Width is key as mentioned above. Also check your local laws...some places only require you to have brakes on 1 axle and other require them on both. - Also check the width regulations. If you are going to be hauling junk cars - I wouldn't suggest something with a wood floor as it gets chewed up pretty quickly. I also wouldn't suggest a 'Full Steel Deck" trailer for junking - cause oils, grease, fluids, etc make it super slippery and dangerous ![]() Make sure to see how many "Cross Braces" are under the trailer and how far apart they are spaced - some don't have very many and the trailer is very Flimbsy. If you want something super nice...check out a company called "Friesen" - I think they are out of OHIO - but they make a super nice trailer and it is Powder Coated and Pinstriped ![]() ![]() ![]() ![]()
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#13 |
67 is sold
Also, our car trailer is open down the middle 9between the rails the wheels roll on).
This comes in handy when strapping a vehicle down as well as any maintenance that may be necessary while the vehicle is on the trailer. |
#14 |
Still drivin' a Rat Rod
We have a 16' dual axle,and a 21' triple axle.
the 16' works alright,but doesn't like pickups,or tractors very well,puts a big load on the tongue/bumper of the truck. The 21' is a much nicer rig.You can hardly tell there is a load on the trailer.It also has a catwalk material in the center to allow fluids to pass through,keeps the walking surface much safer.Also uses trailer house wheels and tires instead of truck wheels.This thing will haul a load. We have to replace the wooden flor in the 16' every couple of years,sure doesn't last long if you really use it.It has been downgraded to a hay trailer for the most part now though.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website Last edited by Brainchild; 06-07-2006 at 10:38 AM. |
#15 |
Parts and more parts
I purchased a dual axle (5200# capability), 18 foot trailer from a a local supplier. He goes down to Texas and picks them up at the manufaturer and saves transportation fees. I got an steel deck with the dove tail, as well as the rock shield on the front of the trailer. The original shield was about four feet tall and I could not see past it good enough when I was jockeying the trailer into a hole, so I shortened it down to 2.5 feet tall. I purchased a WARN winch and created a bolt down point on the trailer bed, so it can be mounted and removed (depending on what I am trying to haul). I haul all of the tie downs, cables, winch, winch battery, and accessories in an aluminum tongue mounted storage box.
The trailer also has four tie-down loops on the bed as well as the post pockets on the sides. This opens up a lot of avenues for the trailer's use. The trailer has electric brakes. The loading ramps are mounted in slides pockets underneath the bed. I have had long bed trucks on this trailer and there was no problem hauling them. The rear wheels set right at the curve of the dovetail and the tie-downs keep them in tight. |
#16 | |
Where's my beer?
Got any pics of the triple axle one? my buddy and I will be building a trailer soon, we scored a free mobile home frame and still deciding if I want to keep the 3 axles and how long I want it (thinking maybe 25-30 ft. long) Thanks ![]()
Paul How do you make the invisible, visible?.........You take it away. |
#17 |
I might be able to get some pics tomorrow,if it's not full of hay.I'll see what I can do for ya.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
#18 |
Where's my beer?
I appretiate it, Thanks
Paul How do you make the invisible, visible?.........You take it away. Last edited by chevy_fatman; 06-08-2006 at 01:12 PM. |
Thread Tools | |
Display Modes | |
