Old 06-08-2006, 10:55 PM   #1
67gmcss
brake lights and turn signals
My turn signals work fine until you hit the brakes and then they stop. The light on the dash even glows but won't blink. That kind of stinks when you consider most of the time when you're turning you hit the brakes. Any ideas on where my problem could be? They all work fine by themselves, but can't seem to get along. thanks in advance for any info.....
67gmcss is offline   Reply With Quote
Old 06-08-2006, 11:02 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: brake lights and turn signals
First thing I'd do is replace all four turn signal bulbs (external...front and rear) with brand new 1157 bulbs.
Then inspect wires... like where the harness had been hacked up for a trailer.
Your grounds should be fine.... don't bother going there.
swap the 2 flashers one for the other....
Do your 4 ways work?
I seem toremember a truck doing this when the 4 way flasher switch was pushed in and broken off... and the flasher was removed.
Old 06-08-2006, 11:54 PM   #3
ed455
Captain Ed
Turn signal switch problems cause all kinds of weird issues. Been there, done that.
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
Old 06-08-2006, 11:57 PM   #4
jrb71c20
jrb71c20's Avatar
and still there
93 Sonoma 2.8/5spd
75 Malibu Classic 350/350
If it don't have round headlights and a carb, I don't trust it!
jrb71c20 is offline   Reply With Quote
Thread Tools
Display Modes
