Rolled on Paint Club
![]() Join Date: Jan 2006
Another trailing arm thread
I discovered a few weeks back that I needed new arms, the old ones were so rusted that I could see through them from the side. Being short on cash, but having a LOT of welding wire compelled me to repair the ones I have. I started by pressing out the bushings and drilling out the rivets to separate the sections. The rust had literally bowed the centers out as it expanded over the years. I hammered the lumps out and cleaned off all the rust with grinders and wire wheels. Then bolted the halves back together with 3/8" bolts and welded the seams together top and bottom. Then cut out a 3' section of rot in the center and butt welded in a 1/4" section of steel I cut out of a piece of 4" angle. The soft bolts will come out and be replaced with G8 bolts in the future. I gave 'em a coat of POR15 and then a coat of ZeroRust. I dont think I will be worrying about rust again
![]() Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
Truck junkie
![]() Join Date: May 2006
Re: Another trailing arm thread
Looks good...probably less flex being welded that way too. Did you get any pics of em after they were painted? Either way nice work!
Looks pretty good. If thats mig welding, your going too fast, and mabee a bit cold.
Too bad you don't live in Texas...I got an extra set.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#5 | |
![]() Bob
PROJECT 7DEUCE
![]() Join Date: Dec 2002
They look good,what is zero rust????
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Thread Tools | |
Display Modes | |
