Old 07-10-2006, 05:17 PM   #1
aggiedave98
need a tach suggestion... any pics??
I would really like to add a tach to my '89 suburban 1/2ton 2wd that has the 2 big guages (mph and fuel) and 3 smaller ones (on the 4 cluster) (voltage, oil pressure, and something... can't remember... plus I added a tranny temp in there on the 4th opening).
Does anybody have pics on where they put theirs?? I don't suppose there is an aftermarket tach that fits in the big hole that also has the gas guage in there, huh???
aggiedave98 is offline   Reply With Quote
Old 07-10-2006, 05:31 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: need a tach suggestion... any pics??
www.73-87.com has a whole write up on doing aftermarket gauges on stock dash, or you could do like me and get a sun pro II take and hose clamp it to the column.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-10-2006, 07:43 PM   #3
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
here is the factory set up in my 81 k5 my 86 k 5 i screwed it on top of the dash
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 07-11-2006, 09:17 AM   #4
aggiedave98
Prerunner1982, do you have any pics?
Igotachevy, do you have pics of the dash one??
thanks guys.
Old 07-11-2006, 10:00 AM   #5
wedgemon
wedgemon's Avatar
I did this...
Works greats and is readable.
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 07-11-2006, 10:07 AM   #6
aggiedave98
wedgemon, looks great!! I like it. What model is it and how did you mount it??
Also, where did you get your steering where and I assume it's a little smaller and thicker than stock?? How do you like that??
Old 07-11-2006, 11:19 AM   #7
Prerunner1982
aggiedave, Oreillys and Autozone as well as most parts houses sell GT grants..
I dont believe I have a pic, but my tach is the larger style, it is mounted just infront of the joint for the tilt column, I dont adjust my tilt so I dont have any problems there. The tach blocks just a bit of the gas gauge, mostly just the check engine light and my gear indicator, but it doesnt work and I can feel what gear I am in anyways.
Jon
Oklahoma Roll Call
Old 07-11-2006, 03:11 PM   #8
wedgemon
wedgemon's Avatar
Cool Re: need a tach suggestion... any pics??
I painted a 4 inch hose clamp black and ran it around the column and tach foot, as shown.
The tach was a Kragen (Shucks, Checker elsewhere) sale item I got a year ago for $25.00. Might be Sun Pro. I've had these before and they can be made to fit in the "Idiot light" spot - lower left of dash - where clock would go. I can see the Tach, Speedo & Gas real well. Will be better once I install my tilt column!!
The Grant wheel is available for about $50 plus install kit ($18) From any major parts chain. I do like it!! I'm 6' 3" and "twohundredandtoomany" pounds. I fit well behind it, whereas the stock steering wheels are a tight squeeze.
- Dave
Founding Member:
Thread Tools
Display Modes
