column shifter linkage problems
Im trying to hook up my shifter linkage rod from the tranny to my column. Im still using a small block in the same location with the same transmission, and it seems like the throttle linkage rod is a few inches too short. Did these rods come in different lengths? What might be the problem?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
Re: column shifter linkage problems
Did you remove the steering column? If you did, perhaps it justs needs to be turned a bit clockwise?
#3 | |
Have you got both levers in Park?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Ok, I have both in park. I have my column lined up correctly b/c the shift indicator thing is right in the middle. I still come up about 3 or 4 inches short. Does anyone have a pic handy to compare to? My v8 is in the v6 position, but it was in this position before I tore it apart and it fit right. If nothing else, can I just weld an extension on the linkage rod?
Thread Tools | |
Display Modes | |
