Old 07-19-2006, 11:09 PM   #1
incoma
incoma's Avatar
driveshaft ?
I've got a 2 piece swb driveshaft. Damn carrier keeps falling apart. I've got a 2.5/4 drop. Is the new angle of the driveshaft screwing up the carrier? Do I need to shim the rear axle?
Also, a local drive shaft outfit said that they can't make a 1 piece for my application as the length of the driveshaft requires a certain diameter tube. This tube won't fit through the crossmember. Is this true? Does anyone else have a 1 piece driveshaft in a SWB truck? I'd like to chuck my 2 piece. I think this is the 4rth or 5th carrier that's detonated on me over the years.
"Green Monster" (Red Sox fan)
1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension
incoma is offline   Reply With Quote
Old 07-19-2006, 11:49 PM   #2
RicksTrucks
RicksTrucks's Avatar
Re: driveshaft ?
There are one-piece shafts. There is a good driveshaft place here in Tulsa. Want me to get their number for you?
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 07-19-2006, 11:53 PM   #3
chevybill
chevybill's Avatar
Re: driveshaft ?
Based on what a powertrain shop told me for my lwb truck, you should not have any problem going to a one piece shaft if you want. They would have custom built a one piece for my lwb, but 3 inch diameter tubing was needed because of the length. I got lucky and was able to use my original shaft. Pm
Txfirefighter for advice about the shims. You might want to try a polyurethane carrier instead of an original type if you stay 2 piece.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 07-19-2006, 11:56 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: driveshaft ?
The swb trucks w/250/3 speed combos have a one piece driveshaft. It clears the xmember so I don't see the problem.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-20-2006, 08:50 AM   #5
incoma
incoma's Avatar
Re: driveshaft ?
I wonder if you need a larger diameter driveshaft depending upon the torque rating of the engine? I've got another shop about 3 blocks up. I'm going to run by there later today to see what they can do for me. It sounds like a 1 pc is possible for my application.
Rickstrucks - Thanks for the offer. I've got another local shop I'm going to try and work with. I'm just trying to get a feel for the validity of the other shops comments.
Old 07-20-2006, 10:11 AM   #6
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: driveshaft ?
I have a 1 piece in my SWB with a 454. We have a drive line shop here in town that’s 2nd to none. I had to remove the carrier holder so the larger diameter shaft would clear. Also my truck in lowered 4 & 6 so I did shim the rear for correct pinion angle. These guys have the shims in a few different degrees. http://www.classicperform.com/6092chevtrk.htm I went with a 4 degree on my truck and it works Perfect. On a side note, we also have a 1 piece in my sons 71 LWB – No Problems
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 07-20-2006, 10:49 AM   #7
incoma
incoma's Avatar
Re: driveshaft ?
Great. Sounds like there's no doubt the first shop I talked to either didn't understand what I was asking, or was going to "overkill" the application. I'll stop by the other shop today and see what it would cost to get one built. In the meantime I'm going to get my carrier housing re-welded today so I can get this beast back on the road.
Old 07-20-2006, 12:54 PM   #8
sleepyboy
'69 Step
Re: driveshaft ?
I had a one peice done for mine (STEP) in San Antonio, Texas. Dude told me unless it is a long bed, 1 peice is fine..$300 seems to ring a bell on price but did eliminate a wobble I had.
sleepyboy is offline   Reply With Quote
Old 07-20-2006, 12:57 PM   #9
nxtruck
nxtruck's Avatar
Re: driveshaft ?
I have a question for you on your truck. You say that you used a 4* shim to correct your pinion angle. What is your pinion angle set at right now? The reason I ask is because I have lowered my '66 lwb and the pinion angle on it is right at 3* down. I had assumed that my angle would be screwed up because of the drop and because of going to a 1-piece shaft. I don't know what the angle is from the factory, as I didn't check it before I dropped it. Thanks...
nxtruck is offline   Reply With Quote
Old 07-20-2006, 01:13 PM   #10
1970 CST Short Wide
Senior Moment
Re: driveshaft ?
Read this http://www.2quicknovas.com/happypinions.html It worked for me.
I had a slight vibration after I lowered it and put the 1 piece in. I thought it was the shaft and went back to the drive line shop and they checked the balance and it was good. They asked if I checked my pinion angle and turned me on to this site. All is good now.
Pittsburg Ca
94565
Old 07-20-2006, 01:35 PM   #11
incoma
incoma's Avatar
Re: driveshaft ?
I just got back from the driveshaft shop. $175 for a new shaft with a 3 1/2" diameter, reusing my yoke. They didn't sell shims though. I thought that was odd, how else do you correct the angle? Perhaps washers? I'll reinstall my driveshaft tonight and check the angle. I think I have a cheapo gauge somewhere.
Old 07-20-2006, 04:21 PM   #12
1970 CST Short Wide
Senior Moment
Re: driveshaft ?
Look above - I posted where you can buy shims. washers would work but these shims are a bit more precise. I got them fairly fast and not bad on $$ http://www.classicperform.com/6092ch...d%20Components
Part # 6072RPS4 1960-72 Truck Rear Pinion Angle Shims, 4°, pair Photo/Info $19.00
Pittsburg Ca
94565
Old 07-20-2006, 04:36 PM   #13
incoma
incoma's Avatar
Re: driveshaft ?
I saw you had posted them above. I was just looking for a local source so I could get some immediate satisfaction!! I agree that shims will be the way to go. I'll be calling them next after I get the measurements.
I've read the article a few times and am not quite sure how the driveshaft angle is measured. I guess I need to read it again. For some reason I'm just dense today. Maybe I shouldn't work on the truck today!
Thread Tools
Display Modes
