Old 07-20-2006, 11:19 PM   #1
pooks64
1965 short bed
I now have a 1965 short bed that I'am driving and it has a 350 and four in the floor trans. I won't to change the rear end to something for 60 plus mph driving and add power steering. What is the best way.
pooks64 is offline   Reply With Quote
Old 07-21-2006, 08:27 AM   #2
Shorty Cox
Re: 1965 short bed
Pook, don't know about the rear end, but converting to power steering is simple. The topic has been covered on the board many times. Do a search and read. First rule is to get the steering box and pump from the same donor truck. (I think it was '85, GM changed from std threads to metric threads.) getting both from the same donor truck will insure the pump will attach to the box. You can purchase a bracket to attach the box to the truck, or, you can do what i did, build you own. (Keep in mind, it is not brain surgery).
Anyway, good luck with the truck. I do enjoy my driver.
Shorty
Shorty Cox is offline   Reply With Quote
Old 07-21-2006, 10:50 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 1965 short bed
If you want to switch to 5 bolt wheels, the best way is to get a front end from a 71-84 pickup. Swap the entire crossmember, you will need to drill some holes for bolts. Look at earlier posts here, it has been discussed before.
The rear end swap is not hard, if you can find one from a coil spring truck. Most are leaf spring, which will mean cutting the mounts off and welding on the ones from your truck.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-22-2006, 01:10 PM   #4
SIR
SIR
SIR's Avatar
Re: 1965 short bed
[FONT="Comic Sans MS"][SIZE="4"][B][I]HOWDY!!! bruce here,a 1972 is a direct bolt in...just make sure all the seals are good and the wheel cylinders are good,and the brake shoes are good.....and you will need some help......
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Thread Tools
Display Modes
