Old 07-21-2006, 03:09 PM   #1
CochinoFilipino
CochinoFilipino's Avatar
Underbed tank/fuel cell and Elec in tank pump
I've got TPI and am contemplating to move the tank out under the bed. I'll want a tank that utilizes an intank fuel pump and have an acurate sending unit.
What would be a good source for this?
I was also thinking of just spending the dough and getting a custom fuel cell built for this application and with baffles.
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
Old 07-21-2006, 09:59 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Underbed tank/fuel cell and Elec in tank pump
Fuel cell guy is th one to talk to for an aluminum tank.
ECE carries a stainless tank (big$$$$)
Rob
Hart_Rod is offline   Reply With Quote
Old 07-21-2006, 11:00 PM   #3
incoma
incoma's Avatar
Just curious, are you running an inline pump now with the original in cab tank? How did you plumb your return line if you don't mind me asking?
"Green Monster" (Red Sox fan)
1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension
incoma is offline   Reply With Quote
Old 07-21-2006, 11:10 PM   #4
CochinoFilipino
It's rigged, ugly and I get fumes in the cab. I bought it like this. It's got an in-tank pump. I'm not sure if the pickup goes deep enough. It sometimes starves for fuel if I hang a turn too fast. It looks like they just drilled a hole in the top of the pickup piece and ran a line for the return.
Old 07-21-2006, 11:14 PM   #5
incoma
incoma's Avatar
I had considered taking 2 in cab tanks and making one. If you use a 71-72 sender, and attach an in tank pump to it at the bottom, you could also build a baffle to sit inside the tank. The 71-72 sender has a return fitting on it already. A guy on ebay sells in tank pump kits. My thought is that I can keep my spare tire carrier in the back and leave the truck looking stock that way. Probably be easier to put one out back, but it may cost more.
Old 07-21-2006, 11:24 PM   #6
CochinoFilipino
Rob
Anyone got his contact info? I did a search and came up with nada.
That's the prob. I'm suppose to be only spending money on the Stang. But the more time I spend on the truck, the less time the stang gets.
Thread Tools
Display Modes
