07-29-2006, 01:28 AM | #1 |
Sand Blast Booster?
Was wondering if there is any problems caused by sand blasting power brake booster , master cylinder and proportioing valve. Long as I seal up back of power booster hole, check valve hole and proportioning valve line holes will the rest of the unit blast ok?
07-29-2006, 01:57 AM | #2 |
Re: Sand Blast Booster?
Ummm, I wouldnt do it. That sand gets everywhere. Use a roloc strip disc from 3m that you can put on a die grinder or drill. Wire wheels work good too.
07-29-2006, 07:26 AM | #3 |
I glass beaded mine without any problems.......Like you said, just tape up the openings........
1997 GMC Sierra Ext 1965 Mustang |
07-29-2006, 07:27 AM | #4 |
its all about the +6 inches
use duct tape on the openings, and lower the pressure on the sandblaster a little.
Thread Tools | |
Display Modes | |
