Old 07-31-2006, 09:42 PM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
battery draw
Well, I posted a while back about my battery draining, got the problem fixed, and now I've got another skeleton in my closet. I'm pretty sure I've got a draw somewhere but not positive. My battery died a week ago, so after every time I drive it now I unhook the - terminal when it's parked in the garage just in case. Tonight I took out my test light and with the - batt cable disconnected, I clipped the test light cable to it and probed the - terminal on the battery. The light barely lit up for like a split second and then went out. I had a good connection on both ends. Why would it not stay lit? I tried again, but nothing. I thought ok, maybe I blew the bulb. So I put the clip on the + side and probed the - side and it stayed lit. I again clipped the clip to the - batt cable and probed the - terminal. Nothing. Any ideas???
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 07-31-2006, 09:47 PM   #2
Louis72
Louis72's Avatar
Re: battery draw
I had the same problem and it turned out to be the voltage regulator in my alternator. I was killing a battery every 2 days. Dont know if thats whats happening to you, but my problem is fixed.
Louis72 is offline   Reply With Quote
Old 07-31-2006, 09:49 PM   #3
centsless
sufficiently talented fool
centsless's Avatar
Re: battery draw
With no draw at all, the light will go out. If it has an aftermarket stereo with a clock, the light may light may come on momentarily while the stereo powers up. If you can, use a digital multimeter and set it on the 20 amp setting. Hook it inline between the negative battery cable and the battery. If the reading is under 1 amp, change the meter to the mA scale. The acceptable reading is anything under 50mA. If it is over that, start pulling fuses till it dissappears. Hope that helps, let me know if you need more.
Bob
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 07-31-2006, 11:36 PM   #4
truckdude239
truckdude239's Avatar
Re: battery draw
my alt. was bad and that was kept killing my battery sounds liek its time for an internal reg swap http://67-72chevytrucks.com/vboard/s...d.php?t=119379
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Thread Tools
Display Modes
