04-18-2002, 11:45 AM | #1 |
whats that smell?
I have to run an electric fan, what should I get?
My '72 suburban 4x4 is in desprate need of a good fan. Heres the deal. I just had a new motor installed and everythings working great, but the fan is not pulling enough air through the radiator. At some point the engine, transmission and transfer case had been moved back 4" inches to the 6 cylinder mounting holes and the fan is just too far from the radiator to pull sufficent air through. I think whoever lifted the sub must have moved all the drivetrain back 4 inches to confinsate for the added lift so they would only have to lengthen the front shaft. Its CRAZY!!! Another thing that makes the project difficult is the fact that the radiator looks to have come out of a 73-80 big block truck, so my fan shroud wont work. I just want to make it simple and install a big electric fan on the radiator and call it good. What should I get to keep the rig cool off road?
Thanks, Erik ------------------ '29 Chrysler model 65 all original, 2nd owner ***FOR SALE*** '63 Impala SS 283, 3-on-the tree, flowmaster 2 1/4" dual exhaust, performer intake, edelbrock 600 carb, chrome 15x8 rally's '65 Impala SS, built 332, 700R4, 3.73, 2 1/2" mandral bent duals w/H pipe, Flowmaster 40-series deltaflows, MSD Mallory, too many modifications to list '72 Chevy Suburban 4x4, NP205, TH350, balanced 357 (.040 350), 268 high energy cam, 9.2:1 comp, 1.94/1.50 heads (ENGINE BUILT BY THE GREAT RAYZOR or if you know him RAY, WHO POSTS ON THIS BOARD AND CHEVYTALK), 3/4 ton leaf springs, 4" lift, 35/12.5/16.5 Grabber MT's, Rancho shocks, Rancho dual steering stabalizer, American Eagle 143's 16.5x9.75 6 lug, 4.10's, 12 bolt rear limited slip, Dana 44 front limited slip. Carter 600, performer intake, headers and flowmaster exhaust system very soon. '74 GMC 1500 Super Custom, Factory 3/4 ton springs, rebuilt 350/TH350, ceramic headers, 2 1/2" duals w/ H-Pipe, 40-series delta-flow Flowmasters, Gibson tips, 15x8 eagle alloy 058 wheels and 31/10.5/15 ProComp M/T's, Fey Outlaw 8" drop bumper. More mods soon... '95 Impala SS Flowmaster cat-back, K&N, 285/40/17 Firehawks, Dark cherry metallic, 27,000 miles, extreamly fun vehicle '95 Chevy K2500, ex-cab, long bed, 350, AT, Flowmaster cat-back, 265/75/16 Mud Kings, 16x7.5 Centerline HT cast wheels, Leer high rise canope, bed liner w/ mat, loaded.**FOR SALE**
'29 Chrysler model 65 all original, 2nd owner ***FOR SALE*** '63 Impala SS 283, 3-on-the tree, flowmaster 2 1/4" dual exhaust, performer intake, edelbrock 600 carb, chrome 15x8 rally's '65 Impala SS, built 332, 700R4, 3.73, 2 1/2" mandral bent duals w/H pipe, Flowmaster 40-series deltaflows, MSD Mallory, too many modifications to list '72 Chevy Suburban 4x4, NP205, TH350, balanced 357 (.040 350), 268 high energy cam, 9.2:1 comp, 1.94/1.50 heads (ENGINE BUILT BY THE GREAT RAYZOR or if you know him RAY, WHO POSTS ON THIS BOARD AND CHEVYTALK), 3/4 ton leaf springs, 4" lift, 35/12.5/16.5 Grabber MT's, Rancho shocks, Rancho dual steering stabalizer, American Eagle 143's 16.5x9.75 6 lug, 4.10's, 12 bolt rear limited slip, Dana 44 front limited slip. Carter 600, performer intake, headers and flowmaster exhaust system very soon. '74 GMC 1500 Super Custom, Factory 3/4 ton springs, built 400sb w/3947040 heads, 475 hp, 750 edelbrock, ceramic headers, TH350, B&M holeshot 2000, 2 1/2" duals w/ H-Pipe, 40-series delta-flow Flowmasters, Gibson tips, Fey Outlaw 8" drop bumper. '95 Impala SS Flowmaster cat-back, K&N, 255/50/17 G-Force T/A, Dark cherry metallic, 27,000 miles, extreamly fun vehicle '95 Chevy K2500, ex-cab, long bed, 350, AT, Flowmaster cat-back, 265/75/16 Mud Kings, 16x7.5 Centerline HT cast wheels, Leer high rise canope, bed liner w/ mat, loaded.**FOR SALE** |
04-18-2002, 12:26 PM | #2 |
I think a shroud would be a good place to start,some people dont likem but id use a fan spacer,but i wouldnt put it on a cheapy flex fan find a oem all metal 6 or 7 blader.
04-18-2002, 12:49 PM | #3 |
whats that smell?
I have to use an electric fan. I already have a shroud and spacer and it doesn't do the job. The fan is more than a foot away from the radiator. I need low speed cooling.
04-18-2002, 12:51 PM | #4 |
Unregistered User
All of the '72 4x4 small blocks have the engine in the 6 cyl position. The 4x4 shroud is deeper, so your fan would still be inside. Maybe get the correct radiator and shroud?
------------------ 71 SWB Stepside Houston, TX
71 SWB Stepside SB400/TH350 |
04-18-2002, 01:10 PM | #5 |
I bought an electric fan setup from Wes. It works very well. I think the site is www.classicheartbeat.com
Bernie |
04-18-2002, 01:28 PM | #6 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I used two 14" PermaCool electric fans with a homemade aluminium shroud.I only need to run one of the fans as it is pretty mild where I live.
You can check out the rest of the pics here. http://www.imagestation.com/album/?id=4292465889 ------------------ "71"blazer,rust free(bought in Arizona),350SBC (375HP),700R4,factory G.M. TPI.Living in Santa Barbara,California.Ongoing project.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
04-18-2002, 05:23 PM | #7 |
whats that smell?
The engine is not on the stock mounting location, its about 4 inches back. I just need to know what kind of electric fan you guys recommend? I need a fan that can really move some air!
Thanks, Erik
04-18-2002, 05:27 PM | #8 |
somebody already suggested the fan kit from Wes.... I'm using a black magic fan from Flexalite, got it from summit.... it pulls 2800 cfm of air.... works great...
------------------ '72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA http://www.ixpres.com/vlusardi/chevtrk.htm
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
04-18-2002, 05:33 PM | #9 |
whats that smell?
Hey bigvinnie,
So you have no low speed cooling problems with that fan? Also is it just a single fan? Thanks, Erik
04-18-2002, 05:56 PM | #10 |
Currently Blazerless
I just got a dual fan and shroud setup from Wes, very high quallity work on the shroud, have'nt got it hooked up yet cause I just ordered a new four core radiator to use it on but I am sure it's going to do a better job than my old setup, if you check I'll bet your motor is in the stock location, I dont see any way to move one back any further than stock.
------------------ 72 Blazer CST, 2-1/2" skyjacker lift with 33x12.50 bfg's 71 Cheyenne K-20,4" tuff country lift with 36's. 69 Custom 30 long stepside 4" rancho lift 36" directional tires,14 bolt rear with detroit locker,dana 60 front with trac-loc 1987 k-5 blazer 2001 Intrepid
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
04-18-2002, 06:44 PM | #11 |
Project Junkie! Fishing Poor!!
Here is the fan system that the guys are talking about. This one is installed in my 4X4 Blazer with a big block. It has been there for over two years and I would never go back to manual fans again.
Here is a link: http://www.classicheartbeat.com/new_products.htm WES www.ClassicHeartbeat.com ------------------ Click (Here) to visit our on-line catolog. E-mail me WEHEPP@attbi.com 72 BB Chevy Blazer 72 BB Chevy Short Fleet 72 SB 3/4 Ton 4X4 72 SB 1/2 Ton SWB 4X4 70 BB Chevy Short Step 70 SB Chevy Short Fleet 69 SB Chevy Short Step 68 SB Chevy Short Step 68 BB GMC Long Fleet 67 GMC 1/2 ton Panel "Founder" Classic Heartbeat Pickup Club Olympia, Washington's "Home For Wayword Chevys" www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
04-18-2002, 07:42 PM | #12 |
Do it well or don't do it
The cheapest way to go would be to get a "Ferd Taurus" electric fan at a salvage yard they blow like a hurricane.
Try to be the person your dog thinks you are. Excellent paint and body site: http://www.autobody101.com/ Visit my Web Site http://home.attbi.com/~agfosteriii |
04-18-2002, 09:08 PM | #13 |
Bite your tounge guitarman... LOL Thems cuss words on these here boards... Hahaha!! WES www.ClassicHeartbeat.com
04-19-2002, 02:05 AM | #14 |
14.1 @ 96MPH
Hey, if you're gonna yank from another vehicle, keep it in the family as much as possible!
Any particular reason for a Taurus? Or would, say, a fourth gen Camaro work just as well? I know those suckers have to have some nasty big fans...they depend quite dearly on them, thanks to having an LT1 and not having a grille... ------------------ Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete! |
04-19-2002, 02:25 AM | #15 |
Yes, it's a single fan, and I mounted it into the original shroud, fits very well... I added an A/C condenser and trans cooler in front of the 4 row radiator, so I needed to pull more air at idle to maintain the temp... now I can sit in traffic with the A/C on, no worries... I can post pics of the finished product if you're interested.
04-19-2002, 06:53 AM | #16 |
Carolina Classic Trucks
I have to agree w/ bigvinnie. I had a perma cool electric fan on my Jeep that has an LT-1 and a 4l60e trans. I added a toyo 4-runner radiatior since it was bigger than the factory Jeep one and the fan could not keep the thing from boiling over. The heavy duty black magic fans WORK! It solved the problem I was having and now water temp dont get above 200 degrees!
------------------ My Hobbies<A HREF="http://photos.yahoo.com/bc/srcjeeper/lst?.dir=/67+truck&.view=t" TARGET=_blank> My 67 CST</A> Carolina Classic Trucks Inc. - coming soon
04-22-2002, 04:49 PM | #17 |
whats that smell?
I think I might go with a single perma cool 16" or 18" inch fan and see what happens.
Thread Tools | |
Display Modes | |
