Old 08-21-2006, 10:17 AM   #1
curbyk
69 C-10 project
curbyk's Avatar
Rattle in front end?
In my 03 Duramax I can feel and hear a rattle in the steering wheel. It is not in the cab. Truck has not been used hard and has about 55,000 mi. I complained about this when it was still under warranty (nowhere near as bad as now) and they squirted some grease somewhere and it went away until it was out of warranty. I have lived with it but it seems to be getting worse.
I'm sure this has come up before but I can't find anything on it.
Does anyone know of a recall or TSB or even what needs to be done before I take it to the dealer and is this a safety issue?
Thanks in advance for the help I know you will provide.
Curby
69 C-10 Work is complete
curbyk is offline   Reply With Quote
Old 08-21-2006, 11:09 AM   #2
bbarooo
bbarooo's Avatar
Re: Rattle in front end?
I have an 02 Tahoe with 22,000 miles that has the same problem. My wife took it to the dealer several times and got the same results. They told us the factory did not use the right grease in the steering column joint. It never did fix it but it was all they would do.
I have a friend who had his column replaced under waranty but mine feels more like front end than steering column.
I would also appreciate any information you guys might have.
Brandon
bbarooo is offline   Reply With Quote
Old 08-24-2006, 05:03 PM   #3
curbyk
69 C-10 project
curbyk's Avatar
bbarooo
Look in my post in the general discussion for some information about this topic.
Curby
Old 09-01-2006, 08:21 AM   #4
1969 C/K CST
A.K.A- Crummy
1969 C/K CST's Avatar
There are some aftermarket pieces that are beefier available. Better than the factory piece.
2003 Silverado Z71 Are fishermen all liars?
1969 C/K CST is offline   Reply With Quote
Old 09-01-2006, 09:00 AM   #5
Joe67
67 is sold
This info should help you out:
http://www.fullsizechevy.com/forums/...d.php?t=219144
Seems a few guys are replacing the stock unit with this one:
http://www.borgeson.com/TruckProductChevy.htm
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 09-01-2006, 02:44 PM   #6
Jonboy
Slots go on anything!
My '05 would get an oil change and steering shaft before they started lubing them. Pulling the shaft and lubing it seems to work better than replacing it, but I hadn't seen anyone here put in an aftermarket shaft.
1974 Jimmy- 5.3/4L80e/NP241
Old 09-02-2006, 10:52 PM   #7
Misled
Misled's Avatar
If you join the forum at http://www.dieselplace.com/forum/index.php and do a search on steering rattle, you will find extensive info on it.
My 05 2500Hd is getting really noisy. I need to look at it.....there is one thread there that said something about a hose clamp that eliminates the rattle....
Take care,
Misled
Misled is offline   Reply With Quote
Thread Tools
Display Modes
