08-28-2006, 10:28 AM | #1 |
Resident Curmudgeon
Need diagrams/schematics/pics for stock A/C
For a 67/68
1. Routing of vacuum lines 2. Routing of wiring harness to connectors 3. Routing of cables from heater/ac control Thanks
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
08-28-2006, 12:47 PM | #2 |
It's a catastrophic success.
Re: Need diagrams/schematics/pics for stock A/C
This is all I have
08-28-2006, 01:29 PM | #3 |
Resident Curmudgeon
08-29-2006, 10:27 AM | #4 |
Resident Curmudgeon
Those diagrams help alot, but the a/c control I have has only 2 vacuum connections in the area circled that shows 3. I assume this is a 67/68 vs 69-72 difference. Anybody have similar diagrams for 67/68 a/c setup? Or is there a 3rd port on the a/c controller I have that is not apparent to me?
08-29-2006, 10:35 AM | #5 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
In the earier versions the vacume line goig to the kick panel vacume pod is "T'd" about midway under the dash.
The T'd line goes to water shut off valve on the pass. side fenderwell. It's possible the 67/68's didn't have that shut-off valve and that's why you only have 2 ports on the back of the selector switch.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
08-30-2006, 10:08 AM | #6 | |
Resident Curmudgeon
Anybody with a 67/68 assembly manual or a STOCK A/C truck? If so any pics and/or explanation of whats going on with the vacuum lines is appreciated.
08-30-2006, 10:26 AM | #7 |
The control head vacuum switch on the 68 has only 2 connections. One from the vacuum reservoir to the control head vacuum switch and the other to the recirculated air door diaphragm (door open when vacuum is applied), this line has a tee about midway which goes to the outside air door diaphragm (door closed when vacuum is applied). the other line on the vacuum reservoir goes to the vacuum source on engine. Hope this helps will look and see if I have a diagram of the whole system.
08-30-2006, 10:42 AM | #8 | |
Resident Curmudgeon
08-30-2006, 12:50 PM | #9 |
Here is some of the diagrams from the 68 assembly manual
08-30-2006, 12:52 PM | #10 |
Send me your email and I will PM you with more info and scans of the manual
Regards |
08-30-2006, 01:08 PM | #11 |
Resident Curmudgeon
Done. This info is extremely helpful and appreciated!
08-30-2006, 03:24 PM | #12 |
Resident Curmudgeon
Thanks to both sneakysnake and 68shortbox. I now have the info I need! I tried to give rep points but for some reason it didn't let me
01-10-2008, 03:29 PM | #13 |
Can someone send me the schematics for the Heater-AC control system for my 72 chevy shortbed?
TJ Rickettsjt@hotmail.com |
01-10-2008, 03:33 PM | #14 |
Still Just Havin Some Fun!
Its information like this that makes the $25 fee seem cheap!
a green one with some stuff done to it.... |
Thread Tools | |
Display Modes | |
