08-28-2006, 10:46 AM | #1 |
Inline guys...Clearance problems:Air cleaner vs. Brake booster
I got a 250 in this K-20 I am working on..........Just like alot of other trucks we had over the years, only problem is this one has a power brake booster on it. Granted I am going to be running a small 4brl Carb on this beast, and the larger stock air cleaner housing isn't going to fit that I has planned on using from a SBC..............BUT, after looking at our C-10 with the stock carb, intake and exhaust, it doesn't look like the stock housing would clear the booster either from what I can see. Does anyone have a picture of a inline with a booster and stock air cleaner setup? I really wanted to run a stock looking setup, although bigger to feed the engine improvements and carb. I thought about taking a stock 6 cleaner and enlarging the center hole and running that.............But that still leaves a small element inside, and heck it doesn't look like it would fit anyhow. Anyone know of a fix beside the lousy looking element sitting on the carb?
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
08-28-2006, 10:55 AM | #2 |
Resident Curmudgeon
Re: Inline guys...Clearance problems:Air cleaner vs. Brake booster
This is the stock 1bbl unit. If you locate one, make sure it comes complete with the support brace, etc.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
08-28-2006, 11:02 AM | #3 |
Wonder how wise it would be to make something similar to that, except the air cleaner housing from the SB would sit on the cross over? I can see it wouldn't work with a 292, but the smaller 250 it might?
Only problem would be flow issues, but I imagine with a 14" air cleaner in it, and a 4brl, all on a little 250, it wouldn't be a huge problem
08-28-2006, 11:22 AM | #4 |
"Trucks with Class"
Notice on cpne's pics there is a fan shroud on that 292, not just the little metal fan guard. That is a real cooling improvement if you are having any heating problems.
A small aftermarket air cleaner will work if you don't care about the stock look. If you run an oval, you can get more filtering area. If you need a 4bbl Offy intake, I also have a real nice one on the parts board for sale. |
08-28-2006, 12:47 PM | #5 |
I would think with a setup similar to stock, you are going to work backwards from the whole point around more filtering area. I put a 4bbl on my 250 a while back, if you are running a k20 booster, be aware that there isn't much clearance between the body of the carb and the booster itself. The idea I came up with (but have yet to impliment), was using one of those cold air intake kits for a TBI engine, It should attach right to a 4bbl without any problems, and you don't have the narrow restriction of the stock 250/pb air cleaner.....only issue with that is colder air is going to cause an I6 to lug even more on start up.
For more on intake heat, check out inliners.org, under the tech-tips there is a good article explaining the issue. http://cgi.ebay.com/ebaymotors/88-90...22556526QQrdZ1 something like this for the intake, the pipe is on the right side for clearance on a 250 with pb. setup.
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
08-28-2006, 12:49 PM | #6 |
p.s. I found the install was "easier" if you installed the carb and intake as a unit, I personally could not get the body of the carb onto the intake and past the booster, I put a few small scuffs on the booster. Once installed I only had 1/4" from the body of the carb and the outer most edge of the booster.
08-28-2006, 01:41 PM | #7 |
"Trucks with Class"
Clearance tight between 4bbl & booster? Look at the pics again and you will see the smaller DD booster that has much better clearance...stops better, too!
08-28-2006, 02:53 PM | #8 |
Thanks guys.............I don't really want to run a aftermarket cleaner on a base like I said earlier, I want to keep this stock, except for the engine mod's internally and like I said, the intake and exhaust, and even that I want to make it look like it could have been on there in '72. I did some hunting in the steel/alum. pile today and I found some box tubing that will work, and I adapt it to a base which I'll mount on top of the valve cover like a stocker, and over to a piece of tubing which I will have the box tubing curve into.
Pickmup, what do you want for the offy? I just bought a Clifford, but I might want another one for a "Future" project. And yes, I got a fan shroud for this one May need it
Thread Tools | |
Display Modes | |
