Old 08-11-2002, 01:42 AM   #1
dregs454
Killin' Time
dregs454's Avatar
5" coil drop, relocate shock mount?????
I was checking out some coil drop kits at early classics, and I noticed that they have rear shock relocators. Is this necessary with a 5" rear drop coil, or is it just another gimmick???
NEED CORVETTE
1972 GMC C20
350, SM465, HEI
Dynomax headers and 2.5" duals
dregs454 is offline   Reply With Quote
Old 08-11-2002, 12:11 PM   #2
loweredd
www.loweredd.com
loweredd's Avatar
Definatly do it. I have done a few static lowerings on truck before. I had a 95 ext cab with 5/6 drop, and shocks in the stock location. If you look at them after with that much drop, they were sitting at about a 140 degree angle. They were almost horizontal. You want the shock to be pretty close to the stock posistion if not more vertical.
loweredd is offline   Reply With Quote
Old 08-12-2002, 09:00 AM   #3
Frank_Zeller
Frank_Zeller's Avatar
At a minim you need to get shorter shocks. You would also need a adjustable panhand bar to correctly center your rear end. I installed the ECE kit. But it looks like you could rotate the stock top shock mounts 180 and get pretty close to the ECE kit.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 08-12-2002, 01:29 PM   #4
LowSeventy
The stock upper shock mount comes down like a triangle, how would reversing it change anything? The 4/6 kit I put on my 70 came with the shocks, rear mount kit and longer pan bar. If I'm not mistaken, you still need those parts with a 5 " spring too.
I wouldn't worry about them trying to sell you anything you don't need, they made the original stuff for our trucks, and everybody else either sells theirs or has copied them. You can tell by just talking to them on the phone that they know what there're doing.
LowSeventy is offline   Reply With Quote
Old 08-12-2002, 01:47 PM   #5
Frank_Zeller
It would move the mount point further back.
Austin-Texas
Old 08-12-2002, 06:32 PM   #6
LowSeventy
I'm not an engineer, and hate to argue your point, but if the bracket is a triangle pointing down and you turn it around, how does it change were the shock mount bolt goes?
Thread Tools
Display Modes
