Old 09-04-2006, 10:09 AM   #1
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
big block swap information wanted
I normally hang around the 67-72 forum, but I have recently gained ownership of a '65 C10 project with no engine or transmission (did have a V8 and T350).
I have a 396 and T400 to go in it. What changes will I need to make for this to work? Any suggestions or links would be appreciated.
Thanks,
Jason
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 09-04-2006, 10:15 AM   #2
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
Re: big block swap information wanted
aluminum radiator possibly for better cooling - maybe heavier springs
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 09-05-2006, 09:53 AM   #3
HugrOrang71
Bite me, import boy
What about the engine mounting/ towers? Will the big block fit correctly in the engine compartment using the original 283 placement and towers?
Jason
Jason
Old 09-06-2006, 01:23 AM   #4
salazar44
65 - Chevy C10
salazar44's Avatar
excellent question? how do i put this on my favorites so i know if a comment has been made?
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 09-06-2006, 10:15 AM   #5
twotons
twotons's Avatar
Depends on the valve covers, it is really close to fitting in the stock location however the tsock fram stands will not allow the manifolds or headers to clear, you can purchase the stands from early classics and then move them one set of holes forward, this will clear for tall valvecovers and you will have to run a short water pump and brackets.
hope this helps.
66 Chevy P/U 1/2 ton (new best Oct 09 9.78 @ 139 w/1.3760ft)
http://i8.photobucket.com/albums/a41...erdd5d5045.gif
twotons is offline   Reply With Quote
Old 09-06-2006, 12:20 PM   #6
HugrOrang71
Bite me, import boy
That is exactly what I needed to know. Thank you
Jason
Jason
Old 09-07-2006, 12:25 AM   #7
raphyel
70-72 engine towers for a big block will make it fit nicely. I dont know about the plumbing, but I used those twers to get a pontiac 400 to fit into my 63 and they work well.
raphyel is offline   Reply With Quote
Old 09-19-2006, 10:22 PM   #8
Slammed66
Needs a Big Block
Slammed66's Avatar
I used 73-87 mounts , when Put the 454 in mine , fire wall was close but had clearance and , I had a long neck set up up front
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 09-19-2006, 10:58 PM   #9
qksilver
I have seen the 73-up used , like slammed said close but fit ok
Get some good brakes, that truck will fly!
qksilver is offline   Reply With Quote
Thread Tools
Display Modes
