Old 09-05-2006, 07:46 PM   #1
2wheeler
2wheeler's Avatar
Which gears to run?
I have 38.5" tires on my '86 and now I don't know what gears to go with. I just rebuilt a 355ci and have a 700r4... I was thinking 5.?? because it's not going to be around any highways and it would be a bonus to bark the tires or leave a patch or something. What do you guys think? Anything is appreciated. Thank you
2wheeler is offline   Reply With Quote
Old 09-05-2006, 08:59 PM   #2
b454rat
Re: Which gears to run?
Take your 38s and divide that by the stock size tires, say a 31. Mulitply that by the current gears, we'll say 3.42s, which comes up to 4.24, so you can go down to 4.10s, or up to 4.56s. Depending on what axles you have, going to a 5.13s will make the pinion real small, and with 38s and a healthy motor could make them and the joints go pop.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 09-05-2006, 09:10 PM   #3
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
i'd say 4.56's or 5.13's
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 09-05-2006, 09:25 PM   #4
2wheeler
2wheeler's Avatar
I found this: Good "rule of thumb" calculation is to mutiply .12 by your tire diameter. (.12 X 38" = 4.56)
So that's probably what I'll do but would it be worth putting the gears into a 12 bolt that I can get or the stock 10 bolt?
Old 09-06-2006, 12:14 AM   #5
2wdBlazer
The Blazer King
2wdBlazer's Avatar
5.13 or numerically higher. I would go with at least a 5.29 beacause you want more power and you have overdrive. That other formula only works for a 1:1 final drive.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 09-06-2006, 01:33 AM   #6
kwmech
That would be my vote also. The 5.13s in overdrive (700 is 28%) is 3.69 final
Old 09-06-2006, 02:29 AM   #7
2wheeler
2wheeler's Avatar
The more and more I look at this, the more and more I get confused.
TH 700R4
1st 2nd 3rd 4th
3.06 1.62 1.00 0.70
NP 208
Lo Hi
2.61 1.00
The reason I put all the ratios is because right now I don't have a front driveshaft so I put the transfercase in four-lo and drive around with 3.08s. I think the gear ratio that I'm looking for is pretty much the truck in 1st/Lo
Sorry about all the questions... This is what I do before I invest, research it and go accordingly and I've never done gears before
Old 09-06-2006, 06:41 AM   #8
vtblazer
vtblazer's Avatar
Naw, it's done all the time and holds up just fine.
I've been wheeling pretty hard with 5:13's and 39.5's without issue.
Pretty common set up among the 4x4 crowd, wouldn't be if it didn't work.
2wheeler, go 5:13's or higher with that over drive.
Did you have the 700r beefed up?
Any pics?
vtblazer is offline   Reply With Quote
Old 09-06-2006, 09:24 PM   #9
2wheeler
2wheeler's Avatar
Any pics?
I was told that the transmission was rebuilt when I bought the truck and I've only driven it once or twice around the block. The only decent pic I have...
Name:  86 Silverado 033.jpg
Old 09-07-2006, 03:52 AM   #10
vtblazer
vtblazer's Avatar
Nice ride.
Leaving it black for wheeling? (looks good IMO)
Or is it about ready for paint.
Old 09-07-2006, 11:56 PM   #11
2wheeler
2wheeler's Avatar
It's wheelin' paint right now but I haven't even got that far and then one day I hope that it'll be nice enough for a gloss black
Old 09-08-2006, 07:56 PM   #12
see ten
WTB this ad
see ten's Avatar
I wouldn't regear a 10 bolt for a tire that tall! If you have a foot of any weight, the axle would be junk in short order. You're borderline on needing some 3/4 or ton running gear there.
see ten is offline   Reply With Quote
Old 09-09-2006, 10:16 AM   #13
1969K10
1969K10's Avatar
You're getting ready to drop a heap o' money on some 1/2T axles that aren't even close to being up for the abuse you're getting ready to hand them.
1969K10 is offline   Reply With Quote
Old 09-09-2006, 11:42 AM   #14
LONGHAIR
I agree........If you really are going to 'wheel this truck, up-grade the rear-end at a bare minimum. You can step up to a 12 bolt and keep the 6 lug wheels, as a lower dollar option. This is not the best way, but the most cost effective for a minimal use non-competition vehicle.
The biggest thing, reguardless of which axles you end-up using, is proper break-in procedure. This is even more important in lower ratio gears like these. First of all use a synthetic lube. Second, drive no further than around the block on the first voyage. Park it and let it cool for a while. Then drive a mile or so and wait again. Then no more than 5 miles or so, cooling again. After that some in town driving w/o highway speed for the next twenty or so. Then you should be good to go. Personally I would pull the cover, inspect the gears (looking for metallic particles in the lube) and change the lube after 100 miles or so.
Again as I always say, do do the gear change yourself. Pay a reputable shop to do it for you. Inquire about their break-in procedures and warranty.
LONGHAIR is offline   Reply With Quote
Thread Tools
Display Modes
