White 82
Does anyone know what year front axle will innerchange to a 1971 4x4 ? from what year to what year?. i have a project that needs a new whole front axle and need to know what will fit?
1966 GTO 455 e-heads, 1982 Chevy k10 4'' lift 33’' tires, 2008 Pontiac g6 v6 |
Re: does anyone know
Any GM front axle '71 or newer will bolt right in. '87 was basically the last year of solid front axles ('91 for Blazers and Suburbans). Axles from 1977 and later will be a corporate 10 bolt instead of a Dana 44, but they will still bolt in. Actually, axles older than '71 will bolt in also, but they will have drum brakes.
Tim Last edited by Blazer1970; 09-14-2006 at 06:07 PM. |
White 82
so everything from 67 to 87 will work on each other other than the differnt balljoints and brakes as far as the front goes?
Location: vacaville ca, because it as far from indy as i can be
ball joints and brakes are all the same for open knuckle axles. any solid axle from a solid axle truck or blazer/burban will fit.
the 67-72 open knuckle axles do use the smaller 267 ujoint but the shaft are a straight swap with the new 73+ d44 297 ujoint shafts. all the parts from the axle C out are the same for the 10b/d44, all the inner part are NOT interchangable. |
Thread Tools | |
Display Modes | |
