The Older Generation
Heater Cable Removal Tip
I did some searching but didn't come up with a post on this. Sorry if it has already been covered….
Here's how I removed the keepers that hold the heater cables onto the control arms without breaking them. The first picture is the tool I used to remove the keepers. It is one of the small pick tools (approx. 4" long) The small hook is easy to get under the keeper and work it up off of the post. Take your time & work your way around the inside of the keeper and push it up off the post. Make sure that the tool is between the keeper and the cable end as shown in the last picture. LockDoc
![]() Join Date: Mar 2012
Re: Heater Cable Removal Tip
well I removed mine yesterday as i was tearing down the cab for paint, and i snapped a couple of the retainers in half.
Where can i find some decent replacement retainers?? I realize this is an older post but you never know...
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Dec 1999
I was just at Ace Hardware over the weekend looking for something similar (a thin thread on nut). I'd check your local hardware store in the nut & bolt section. Ours had several automotive trays which included some of these push on clips.
67 GMC C2500 GMC V6 4spd NP435 Dana 60 4.10 Power Lok |
Will do Thanks
Scrapper 1
best off to lube them before you pick at them
![]() Join Date: Feb 2019
You can find Push Nuts here..
https://apexfasteners.com/fasteners/...treg-fasteners
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
NAPA has them or can get them if you have one local to you. LockDoc
Thread Tools | |
Display Modes | |
