Out of money
Just A Few Pics
I've never posted pics befoe but here is my first try. This is my 1969 C10. I got this for $500 and drove it home that day. The brakes need some work but it is driveable. I tried to sand a little of the rust off and spray some primer from a can just to keep it from rusting anymoe. the motor is out of a 1971 Monte Carlo. The guy told me it has double hump heads but i am not sure of the casting numbers yet. He also said that he bought a cam from a local Chevy dealer but he couldn't remember the specs. He said it ran around $300. I hope you all enjoy. This is my first project so I will be larning as I go.
Re: Just A Few Pics
Those heads are double humps by the way. If you look on your fifth picture where your fuel line almost touches the head you can see the "doublehump" or "camelhump" Just one way to identify them.
Re: Just A Few Pics
Welcome from Colo. My wife and I have some friends in Harriman, pretty close to your neck of the woods. A running truck for $500 is good. You could get almost half your money back selling the valve covers. It looks a little rusty on the firewall, how bad is it?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Re: Just A Few Pics
drivable is always a good thing. like said above sell the corvette valve covers and put it into a tune up for the engine (the right size air-cleaner-14"
,plugs,wires,cap/rotor,oil,filter,rad flush etc.) and im betting it will run strong for a long time. def. a good deal since you got a set of camelback heads with the engine. looks like ya got some rust repairs to get on though ![]() Last edited by QKENUF4U; 10-08-2006 at 07:38 PM. |
WTB this ad
Re: Just A Few Pics
Great job! I'm diggin the valve covers and the glovebox speaker mod! Someone is always comin up with another solution for mounting speakers in these bad boys!
Re: Just A Few Pics
Looks like a pretty good deal for 500. Like the glove box speaker box. Deffinently different. It looks like the cab is pretty well wasted but of course you can always get another cab. Still killer deal. Hay if I was you I would keep the valve covers. I like them cause there aluminum and they seal alot better than steal and the important thing, they look cool.
Aaron |
Re: Just A Few Pics
Good deal. Looks like you will have plenty to keep you busy, but so did I when I got mine.
Out of money
Re: Just A Few Pics
Thanks for the comments. The only bad thing about the speaker in the glove box is he didn't keep the cover. I wished I had this instead of the speakers. It's hard to work on something with no garage but I work on it as I can. What were the valve covers originally on? I have heard that they were fairly pricey.
Re: Just A Few Pics
Last time I saw them, sold as repalcements in a catalog, was about 130 per side, and that was about 5 years ago. As for you wanting the glove box door they sell them new, look on the parts board, or find one in a junk yard.
Aaron Last edited by Aarons72s; 10-09-2006 at 12:10 AM. |
Re: Just A Few Pics
The valve covers were on '70 LT-1's, I know that for sure
Firefighter
Re: Just A Few Pics
How can you identify the heads??? I'm missing something
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Re: Just A Few Pics
Where the fuel line comes up right in front of the heads on this picture, there is a camelhump or doublehump cast into the actual head. Thats how you identify a set as being "doublehumps" or "camelhumps."
#13 |
Firefighter
Re: Just A Few Pics
Cool I have heard of them but never actually knew what they looked like. What is special about them exactly, that people seem to want them so much?
#14 |
Re: Just A Few Pics
I think they are the big valve heads? 202's instead of 194's? Someone will chime in soon with a right answer, as I have since forgotten.
I like the valve covers too! |
#15 |
its all about the +6 inches
Re: Just A Few Pics
I'd sell the heads to some one who thinks they are still worth something and then buy better ones... cheaper.
5 bills and drove it home... you just can't beat that. I only drove one of my trucks home... and I shouldn't have. Interestingly enough, it was also the one I paid the most for. ($1000) |
#16 |
Re: Just A Few Pics
That's what I was thinking, why do people still want those heads?
#17 |
Re: Just A Few Pics
restorations are about it..........depending on the casting dates Vette guys wll pay some big bucks
#18 |
Out of money
Re: Just A Few Pics
According to the casting numbers they are the 291 heads. I looked the numbers up on mortec and it said a 67-68 model year with a 64cc chamber. I am in the process of rebuilding the motor now. I was going to replace the valve cover gaskets and fix the oil leak but that turned into another project. I went to take the intake off and have it bead blasted but when I did I didn't drain the radiator.
![]() Last edited by trlrider77; 10-23-2006 at 02:48 AM. |
#19 |
The Older Generation
Re: Just A Few Pics
trlrider,
I used the complete front crossmember and power steering box out of a 1973 chevy 1/2 ton 2wheel drive in one of my trucks and the same out of a 1977 pickup in the other. I think the later ones are the same from 73-80 or 81. If you have the motor out this is the way I would go. You have to redrill one hole in the frame on each side and enlarge another one. (see pics) other than that it is a bolt in. The hole that has to be re-drilled can be done on the outside of the frame after the crossmember is in but the one that has to be enlarged has to be done before. LockDoc
#20 |
computer illiterate
Re: Just A Few Pics
my thoughts exactly!
72 2wd blazer 72 swb 4x4 |
#21 |
BlahBlahBlah
Re: Just A Few Pics
I'll trade you two glove box doors for those valve covers
#22 |
Mejor Que Nada
Re: Just A Few Pics
looks like you have a good start going
The only thing that separates "Dreams" from "Reality" is TIME and MONEY!!! |
Thread Tools | |
Display Modes | |
