Old 10-09-2006, 09:03 PM   #1
qksilver
Questions for Longhorn Man....
Wasn't sure about Pm, ing you.
I found on Craigs list today, just listed, a GM good wrench 292 reman motor, less than a 100 miles from home.
I talked to the owner and he said it had gm Mexico on the block.I have some casting #'s
Questions are.........
Where can I find out about the #'s
Did 292's come with A/C and P/S?
Are 2 wheel and 4 wheel engine frame brackets the same, my truck has the 292 4X4 crossmember already.
i am doing that 67 swb 4X4 CST and want to make it look factory, orginal style engine(292) but want to be cool (A/C) and easy steering
qksilver is offline   Reply With Quote
Old 10-09-2006, 10:29 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Questions for Longhorn Man....
1) i'd guess mortec.com for tracking the numbers. Being an inline, they may not cover it there. I usually start by just plugging them into a google search and see what happens.
2) Yes, but very uncommon...esp the A/C
3) I don't know, but I would imagine so being that an inline would be in the same location 2 wheel drive or 4 wheel drive...but again, that is an assumption.
Please, anyone feel free to correct me on this stuff if I am wrong... I am kinda lacking on my inline and 4X4 info.
Old 10-09-2006, 10:50 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Seems like cpne would have the anwsers to those questions also maybe jerry moss..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-10-2006, 03:56 PM   #4
qksilver
CPNE? don't know what that is............
Longhorn I was being lazy, figured I would ask first before started searching. Everytime I start a search I end up finding something else and i want to buy it!
Old 10-10-2006, 07:13 PM   #5
Longhorn Man
CPNE is a member who would e able to answer your questions without questioning himself.
Old 10-10-2006, 09:02 PM   #6
qksilver
Old 10-10-2006, 09:11 PM   #7
I know 292's came with power and A/C...but as far as brackets differing from 2wd and 4wd, you got me on that one.
I know the V8's were different because they moved them back to the inline 6 position for drive axle clearance. Since the 6 sits in the same spot for 2wd & 4wd, I would assume they are the same frame brackets/stands. However, like Andy, I don't a whole lot of experience with the 4x4 sect.
Old 10-10-2006, 10:02 PM   #8
qksilver
Neither do I, I decided to return the 67 to factory, the only exception will be the P/S. The it is a well optioned truck and has a good running 350 but it came with the 292. Funky crossmember
Thread Tools
Display Modes
