Old 08-14-2002, 03:22 PM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
How do I stroke it?
hehe.... Anyway, what all is involved in stroking a 350 and making it a 383? Do i just replace the crank, or do I have to bore the cylinders and get new pistons/rods? Who makes a good stroker kit?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 08-14-2002, 03:38 PM   #2
68 with 350 TPI
68 with 350 TPI's Avatar
1)Well you will need pistons with the right height at the pin to fit.
2) a 400 crank with the jurnals turned down to fit a 350 or a aftermarket one like scat etc.
3) boring out the block.
4) taking some metal away from the block to clear the stroke.
5) most of the time you will also need to do some grinding on the rod bolts to get it to clear.
5) a cam that will work better with the 383 combo instead of what you would run with a 350.
6) you will need to balance it and use a flywheel like a 400.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 08-14-2002, 03:38 PM   #3
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
stroking, ummmm lets see first you do the four finger drag over the vasaline.....no wait you have to have the 350 block line bored to take a 400 crank & connecting rods, then have screw in studs put in for the heads, try P.A.W. performance-autowmotive-wholesale.....they have a kit not sure on the $$$$ & you have to get the 350 machined to take 400 journals also....I think...been a couple since I built 1 I think thats about it thow..........
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
rebelryder@hotmail.com
diggin69 is offline   Reply With Quote
Old 08-14-2002, 03:52 PM   #4
Beast388
Suburbans RULE!
Beast388's Avatar
Speed-O-Motive has some good kits.
www.speedomotive.com
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 08-14-2002, 04:32 PM   #5
Tracy Focht
Tracy Focht's Avatar
These guys have great stroker kits as well.
stroker
Tracy Focht is offline   Reply With Quote
Old 08-14-2002, 05:49 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Or you could just build the 400 that you rape for a crank, and save money and get more torque.
Old 08-14-2002, 06:42 PM   #7
nate68
i built a 400 'cause it was easier for me. 23 more cubic inches (406) has got to make some kind of difference. super chevy, hot rod, etc. need to do dyno tests and compare a 383 to a 406 and see what the differences in power are.
either way make sure you use 5.7 (350) or larger rods. if you're willing to spend the extra dough get 6" rods
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 08-14-2002, 09:18 PM   #8
>X<
registered IWATA user
>X<'s Avatar
thats just sick
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Thread Tools
Display Modes
