Old 10-30-2006, 08:06 PM   #1
1969k10stepside
Talking My now lifted 69 K10
Well,Its sort of lifted.The back isnt on yet.It is supposed to be a 6 inch lift but I think it has more lift.Dont y'all think?I cant wait till the back is on.I will posts some more pics when Im done.Here it is now Im almost there.Now I just need some tires...
1969k10stepside is offline   Reply With Quote
Old 10-30-2006, 08:07 PM   #2
gmcman7202
Active Member
gmcman7202's Avatar
Re: My now lifted 69 K10
that rake is awsome,, so much more sexy than my 02 sierra
gmcman7202 is offline   Reply With Quote
Old 10-30-2006, 08:39 PM   #3
71chevytruckguy
71chevytruckguy's Avatar
looks like a raised up lowe rider. lol. what size tires you puttin on it? 35's? chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 10-30-2006, 09:03 PM   #4
1969k10stepside
I dont know what size tires are going on it.35's or 37's though...
Old 10-31-2006, 05:53 AM   #5
vtblazer
vtblazer's Avatar
My guess is that the motors out...is it?
35's with a 6" lift always looked right IMO, w/37's and any real wheeling you'll rub.
vtblazer is offline   Reply With Quote
Old 10-31-2006, 08:49 AM   #6
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I think you should step it down a notch. Go with some Geo metro tires and that will give you the added clearance. Definatly should not rub with those. You could kick it up a notch for added clearance and use Ford Festiva tires. They even use a 12 inch rim. They will look awesome in a SSR radial or something like that.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 10-31-2006, 10:05 AM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Keep at it and it will be on the road before you know it.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-31-2006, 10:20 AM   #8
1LoC10
Insert Title Here
1LoC10's Avatar
cool......... just put some 13" wire wheels and some white walls, and your set
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 10-31-2006, 05:30 PM   #9
1969k10stepside
Here is current pics w/ the axle waiting on the rear suspension to be put back together so the truck can roll around...
Old 10-31-2006, 05:33 PM   #10
gmcman7202
Active Member
gmcman7202's Avatar
who needs a real axle... put it in 4wd and just drag the rear around, tires are so over rated anyways.....
Old 10-31-2006, 05:33 PM   #11
1969k10stepside
You can really see all the dents and rust and lack of a gas tank in that pic....Yes the motor,tranny,and t-case are out right now.They are sitting in the garage awaiting the motor to be finshed...
Old 11-01-2006, 09:40 AM   #12
1969k10stepside
Well,I woke up today sick so the lift wont be on for awhile depending on how long I am under the weather.I guess it will sit outisde for awhile until I feel good enough to move it inside the garage..
Old 11-01-2006, 01:35 PM   #13
1969k10stepside
Well,I decided that Im going to try to get the truck in the garage so I can work on it out of the cold and after dark...
Old 11-05-2006, 07:51 PM   #14
1969k10stepside
Well,The lift kit is done.Well I still need to put on shocks but the lift is on...
I took pics but it was almost dark so they didnt turn out so I will get some tomorrow...
Old 11-06-2006, 12:07 PM   #15
chipflyer
chipflyer's Avatar
What did you do with your old springs? Are they in good condition and are you going to sell them?
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 11-06-2006, 05:59 PM   #16
1969k10stepside
Here is what it looks like now.It just needs some tires make it look like its ready to hit the trails.The driveshafts will probably need to be modified though......
Old 11-06-2006, 06:09 PM   #17
1969k10stepside
The springs on that truck were no good.I am getting an all spring lift for my 71 swb K10 so I might sell those when I put the lift on it.But I need to be a subscriber first which I plan to do before next year....
Old 11-06-2006, 06:11 PM   #18
1969C/10
Unskilled Labor
1969C/10's Avatar
Looks awesome Dustin. Congrats on the progress!
1986 K/20, 350/TH400, My First 4x4.......
1969C/10 is offline   Reply With Quote
Old 11-06-2006, 06:13 PM   #19
1969k10stepside
Thanks,now I am going to get it one color and replace some cab corners,rocker panels and maybe the bed.....
Old 11-06-2006, 09:40 PM   #20
1969k10stepside
Here is a photoshop.I like the look of it....
Old 11-07-2006, 02:46 AM   #21
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Looks Good. Keep Up The Great Work!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 11-08-2006, 11:22 PM   #22
mothertrucker424
mothertrucker424's Avatar
what kit you use?? kit specs??
mothertrucker424 is offline   Reply With Quote
Old 11-08-2006, 11:33 PM   #23
Senator350
Senator350's Avatar
it looks like it has the saggy butt syndrome that a lot of 6" spring kits have.
i'd throw a zero rate in the rear spring pack.
and 35"s are the way to go.
btw, i have a set of zero rates and some 35" bfg ATs for sale
i feel so dirty whoring myself like this
RN U OVR
Senator350 is offline   Reply With Quote
Old 11-09-2006, 12:22 AM   #24
1969k10stepside
I forget what kind of lift it is(I bought it used) but I can find out tomorrow for you.
Old 11-09-2006, 12:23 AM   #25
1969k10stepside
It doesnt have saggy butt syndrome,it had no motor in it during that pic,it will sit lower in the front than the back once the motor is in...
Thread Tools
Display Modes
