Old 11-01-2006, 11:22 AM   #1
409biscayne
409biscayne's Avatar
Rattle can paint
I need to paint some rear suspension pieces semi gloss black , any paint better or worse than another ?? I usually powder coat , but trying to keep the costs down . Whatta y'all use ?
Tks .............................. 409
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 11-01-2006, 11:25 AM   #2
cdowns
cdowns's Avatar
Re: Rattle can paint
i either will use rustoleum or the duplicolor engine enamel
Old 11-01-2006, 11:26 AM   #3
shifty
Questionable
shifty's Avatar
If I redo my frame and want something that's going to last, I'll probably sand the frame down, then get Eastwood's chassis kit - comes with their Rust Encapsulator product and their Chassis Black product in one package. It's very reasonably priced. www.eastwood.com
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-01-2006, 11:50 AM   #4
409biscayne
Oops , i probably should have said i'm just painting the trailing arms , and there not rusty at all , i just want something that looks good and will last .
Tks.
Can-Am Motorsports
Old 11-01-2006, 11:52 AM   #5
shifty
Questionable
shifty's Avatar
Rust Encapsulator is intended to make it last
But if you want something that will last, just pull the trailing arms off and take em in to have em powdercoated.
Old 11-01-2006, 12:07 PM   #6
BowTieOgre
I know what you mean about keeping the costs down. I was originally going to have my frame and suspension blasted and powdercoated for $500 but I ended up using a friends blasting equipment and painting everything myself for about $80. I rolled on 2 quarts of Gloss Black Rustoleum on the frame and used spray can primer and paint for the trailing arms, control arms, center link, etc. It looks pretty good so far but not great. It looks like the Eastwood kit is about the same cost as all the supplies I got from Lowes but Im not so sure about 4 rattle cans doing everything.
I will try to put up a pic this afternoon of my trailing arms.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 11-01-2006, 12:17 PM   #7
cdowns
cdowns's Avatar
if your idea of savin money is having them powdercoated maybe he could have them chromed and save a bundle!!!
Old 11-01-2006, 12:27 PM   #8
Green Machine
Green Machine's Avatar
On the trailing arms I would put down Rustoleum rusty metal primer first and then topcoat with Rustoleum semigloss. I think the quart can stuff is better than the rattle can, but either will be fairly cheap and work pretty good I think.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-01-2006, 12:43 PM   #9
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
If I was you... I would go to a farm and tractor supply and try and find Van Sickle Implement enamel. I believe there is gloss, satin, and flat black colors in it. We bought a gallon of the gloss black and it was enough to paint everything on my 1996 extended cab frame. The stuff is really nice and thick and flows well. When we crack back into my 1971 4x4 again... we are going to blast my frame and I will be using this product again. Holds up pretty well to things, better than Rustoleum or others in the price range. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-01-2006, 12:43 PM   #10
71blksuper4x4
SWB 4x4 Collector
I forgot to mention that the last time I was at a Tractor supply I noticed they made this in rattle can too.
TREVOR
Old 11-01-2006, 01:10 PM   #11
1LoC10
Insert Title Here
1LoC10's Avatar
well my trucks just a driver and I just didnt like the look of rust.. my enitre frame and all the suspension and rear end and everything was solid rust on mine..lol ... so I sprayed everything I could with "Semi Flat Krylon Rust Tough Enamel" it holds up pretty well, and looks better than rust
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 11-01-2006, 01:11 PM   #12
shifty
Questionable
shifty's Avatar
I reckon you can get those trailing arms powdercoated for $75, which is about $40 more than you'd pay loading up on paint, and in man hours, fume inhalation, etc.
Overall, the Eastwood method would work, but ... I dunno.
Old 11-01-2006, 01:25 PM   #13
BowTieOgre
Here are pics as promised of my Rustoleum paint job. The frame JUST got moved back inside after being painted so its a little dirty but it used to look like the other pieces.
Old 11-01-2006, 02:53 PM   #14
jimmydean
jimmydean's Avatar
The way to do it is to build your own powder setup. I built mine about 8 years ago for a total of $200. Not only did it pay for itself the first run, but I have made close to $5000 over the past 5 years shooting little stuff for guys I know.
I bought the Eastwood hotcoat gun (junk out of the box, but I rewired it) and picked up an oven from a yard sale for $25. Pulled the elements out, welded up a 6'x3'x3' box with a small window in the door and mounted them on the bottom. Painted the inside of the box in high temp white and mounted the controls to the top. It's ghetto, but you would never know based on some of the custom stuff I've shot.
Powder runs about $5-$15 a pound. A pound will do about 4 sets of trailing arms with an even coat. I no longer have a shop of my own, so we set the stuff up in a friends garage. It's not as easy to use now, so I haven't done a whole lot. But if you want to do projects right, it's the way to go for sure.
I saw an article where a guy built an oven out of an old metal container. He couldn't fit larger items in it, but it was way easy compared to my setup.
<edit> DO NOT BUY EASTWOOD POWDER! It's crap and expensive. I buy mine from a local shop in 1 pound increments. You can also buy it from Pendry Powder (sells on ebay) and he ships USPS the next day.
jimmydean is offline   Reply With Quote
Old 11-01-2006, 03:32 PM   #15
cdowns
cdowns's Avatar
yep he could build his own chrome tanks too for less money than your setup
Old 11-01-2006, 04:13 PM   #16
beater69
Sinister Exaggerator
beater69's Avatar
Hard to beat brushing on rustoleum. get a qt for $7 a hand full of throw away brushes for a couple bucks. it goes on really nice and brushing it doesn't hardly stink at all. the rustoleum spray bombs are around $5 and they really stink and put more in the air than on your piece. Crap.....Longhorn Man just painted his truck with the stuff and I'm planning on doing the same. I guess I'm starting to sound like a commercial for the stuff.
69 c10 Chevy Long Fleet 350/350 *under construction*
Poor man's disc brake upgrade with HydroBoost from '82 diesel
Blazer tank with "John Fabris" stake pocket filler (Genius!)
beater69 is offline   Reply With Quote
Old 11-01-2006, 04:21 PM   #17
JAKES 68GMC
Aluminum slot wheels rule...
Rustoleum all they way.
JAKES 68GMC is offline   Reply With Quote
Old 11-01-2006, 04:55 PM   #18
shifty
Questionable
shifty's Avatar
Hey jimmydean, when you say you "rewired" the gun, in what way do you mean?
Old 11-01-2006, 10:35 PM   #19
wibilly
wibilly's Avatar
i used satin rustoliem on my frame and underside of cab and box,i mixed and sprayed mine, thined with acitone and added hardener and ues spray bombs for touch up
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 11-01-2006, 10:41 PM   #20
byrd
Union Electrician
byrd's Avatar
I used the eastwoods kit on my frame, it was $100 for the entire kit, but it wasn't enough paint do it all, so I ordered 4 more cans($40) and it turned out real nice.It is an epoxy paint so it should hold up pretty well.I took a lot of time cleaning and prepping the frame to ensure good adhesion and the truck will be a driver so we'll see.Pics in my sig
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-02-2006, 12:28 AM   #21
Aarons72s
Here is one I have used. I painted a railroad switch, I am a railroad buff, that is in my back yard to see how a certain spray was. It is the appliance epoxy rattle can paint sold at lowes. I put it on early this year and it looks great still. This stuff is real hard after a couple of weeks. Alot harder than any other rattle can spray paint. Hope this helps.
Aaron
Aarons72s is offline   Reply With Quote
Thread Tools
Display Modes
