Old 08-16-2002, 11:58 AM   #1
dubie
dubie's Avatar
Question Who has done this change over before?
It's the ol inline 6 swap to the 350 thing again. I figure if I'm gonna rebuild the engine and everything else, I might as well move the engine up to the V8 position. My questions is about the 3 spd tranny. I take it, it will have to be moved up as well, but what do you have to do to it. The shift linkages would be out and so would the driveshaft. I need some input on this problem.
Wondering if I should just hold off and get a 4spd and do it right.
Any thought on this?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 08-16-2002, 12:04 PM   #2
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
all you have to do is take the six out & put the 350 in you can even use the fly wheel of the six & put on the 8 you will need to get a differnt pivot for the clutch that goes on the side of the block if you are going with headers, other than that you should have no problems, the H.E.I. will be a very tight fit but it all can be done!
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
rebelryder@hotmail.com
diggin69 is offline   Reply With Quote
Old 08-16-2002, 12:17 PM   #3
dubie
dubie's Avatar
Yeah, that's if I drop my 350 on the inline stands, but what if I move the engine up to the V8 position?
Old 08-16-2002, 01:00 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Would you be looking for the truck 4spd or one of the sportier 4spds? If you get to The TwinCities area of MN I have a complete truck 4spd sitting in my machine shed right now. Came out of a 72 GMC C20.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-16-2002, 01:09 PM   #5
Estanley
Estanley's Avatar
You'll need sbv8 engine towers, a longer drive shaft (I've been told that its 59 1/2")and the pivot for the clutch that has been mentioned. I think it is called a Z-bar. I think you will also need the auto crossmember. I know you are going to run the 3 speed man. but when you move it up you will need the auto xmember to bolt to the tail of the tranny. You'll also have to remove the I6 tranny xmember of you are moving things up.
Estanley is offline   Reply With Quote
Old 08-16-2002, 01:23 PM   #6
tkeduk8r
tkeduk8r's Avatar
hey da-burb, i just live up here in St. Cloud.. and i just bought a 74 c10 2wd w /I6 and 3ontree... but would like some info on that 4sp you got int he shed... i dont know if i want to go there, this is a beater to pick up parts for my 70 and engine for the 84 olds, but then i am an addict and would like the creeper gear... any details??? thanks
--mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 08-16-2002, 01:25 PM   #7
okietruck
I did my swap exactly like diggin69 said. I got some V8 stands from the salvage, mounted them to the engine, stabbed the engine, marked the bolt locations, pulled the engine and drilled the holes. Worked out great.
okietruck is offline   Reply With Quote
Old 08-16-2002, 04:15 PM   #8
diggin69
diggin69's Avatar
That V-8 will drop in you dont have to move anything & the motor mounts for the 6 will work you wont have to move anything or get V-8 mounts the only thing is if you go with a H.E.I it will be tight......but almost all the stuff you have know will work, even the fly wheel off the 6-banger.
Eaton,Oh
Old 08-16-2002, 04:49 PM   #9
dubie
dubie's Avatar
I think I will more than likely stay with the V8 in the inline position. I will have the father in law, channel the firewall where the HEI sits. He's a Boilermaker/welder/mechanic, so he's kinda my ace in the hole when it comes to metal work and mechanical.
Old 08-16-2002, 06:42 PM   #10
BobM
Hey Dubie
I did the I6 to SB V8 a couple of years ago. Used the I6 mounts, bell housing, clutch assembly, starter & rad. Only problem I had was converting the clutch linkage. Had to fabricate an engine pivot ball bracket for the "Z" bar. When using the I6 location the pivot ball mounting hole is about four inches too far back. The other only other problem you might have is connecting up the accelorator linkage to the carb. Also if you are using ram horn exhaust manifolds, get the ones with the straight down outlets. The angle back ones won't clear the clutch linkage on the driver's side.
A lot of guys prefer the I6 location for the V8 as it sits lower and further back giving you better wait distribution and centre of gravity.
Bob
BobM is offline   Reply With Quote
Old 08-16-2002, 07:17 PM   #11
Jwill41
Jwill41's Avatar
mine is in the 6 position
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-16-2002, 07:23 PM   #12
Jwill41
Jwill41's Avatar
maybe this time
Old 08-16-2002, 07:28 PM   #13
Jwill41
Jwill41's Avatar
in the 6 position
Old 08-16-2002, 07:33 PM   #14
Jwill41
Jwill41's Avatar
and
Old 08-16-2002, 08:50 PM   #15
frost89434
frost89434's Avatar
I've got mine in the I6 position and didn't even have a problem putting in the hei.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 08-16-2002, 09:16 PM   #16
Gordo
Smile
Dropped my 350 in where the six in a row sat, no problems, including the HEI.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Thread Tools
Display Modes
