Old 11-23-2006, 02:50 PM   #1
55chevy
Car Truck Bike Nut
55chevy's Avatar
Inner Roof Panel Replacement
Finally got around to replacing my rusted inner roof panel on my 1970 C10, a buddy gave me a donor roof section, I decided to replace the entire panel from the front to the back seam joint since it was rusty even above the doors. I drilled the spot welds from the donor panel, and the welds at the back joint came apart easily with a chisel, much easier than the joint in the truck.
The donor had a small amount of bondo and holes in the front, so I repaired it with fiberglass cloth and Chassis Black pant, real sticky, hard stuff.
I used a chisel ground old screwdriver to seperate the spot welds of the rear joint in the truck, make sure to only pry against the old top panel at the surface, it took some work hammering from each side for each spot weld.
Snow free Florida panhandle, don't miss Indiana winters
Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL
68 shortfleet project
94 3500 TD dually
so many cars so little time
72 K2 CST 2WD Blazer
55chevy is offline   Reply With Quote
Old 11-23-2006, 02:52 PM   #2
55chevy
Car Truck Bike Nut
55chevy's Avatar
Re: Inner Roof Panel Replacement
I put rust treatment, primer, and seam sealer around the inside edge of the old roof while I had the roof out.
When you slide the new panel up into place you have to fit one of the triangle shaped tabs at the front into the slot on one side first, then I used a rubber mallet to pound the other one up into it's slot. The new panel at the back was raised up in the middle so I made a hook to pull it down into place
for gluing. I used JB Weld along the back joint, spread it in spots with a popsicle stick, pulled the roof tight with a strap clamp, and put strapping tape over the JB Weld to hold it in place. A 4 inch section on the passenger side worked it's way above the lower section over night by about 3/16 inch, but other than that the rest turned out pretty well. I still need to weld the holes along the side and front to complete the job, this isn't going to be a show truck so looks a lot better then it did.
Old 11-23-2006, 08:08 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Man, that's pretty awesome. Kinda scary to see how rusty these trucks are when you pull them apart. Mine doesn't have any inner roof holes but I'm sure it's coated with surface rust in the inside.....
And I just have to ask... is that an alabama truck? That seems odd to me how rusty it was? I guess the seam sealer cracked out and it leaked for years?
Great job
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-23-2006, 09:08 PM   #4
qksilver
what about using the new stuff, body ahesive? Would that be stronger.
Good work.........I wouldn't have had the patience.
Wanna do my outside cowl panel? lol
qksilver is offline   Reply With Quote
Old 11-23-2006, 09:49 PM   #5
roj2323
hey thanks for the pointers. they will come in handy when i do mine.
ondrew
roj2323 is offline   Reply With Quote
Old 11-24-2006, 05:31 PM   #6
55chevy
Car Truck Bike Nut
55chevy's Avatar
Yup, Alabama truck, seam sealer was gone on drip rail. Not as many old cars and trucks around here as I thought there would be, and they are rustier than I thought.
94 3500 TD dually
Old 11-24-2006, 11:24 PM   #7
qksilver
The humid south! Around here it is the pine needles combined with the humidty that causes the rust out
Old 11-25-2006, 07:43 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
where the rear section lifted, how about drilling a series of small holes and using eye hooks to pull it down. you will have to spot the holes back in but at least you could get it even.
how are you gonna attach the rear joint? is it too late to use panel adhesive? the reason I ask is mine moves some while driving on bad roads.
68C15 is offline   Reply With Quote
Old 11-25-2006, 12:59 PM   #9
55chevy
Car Truck Bike Nut
55chevy's Avatar
I used JB Weld on rear joint, it's similiar to panel adhesive, stuck very tight now. I'm not to concerned about the uneven section, it's just a driver, will be for sale.
94 3500 TD dually
Thread Tools
Display Modes
