Old 12-08-2006, 01:30 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
700r4 questions
im looking into getting a 700r4 off of a friend but one of the bolt locations is broke meaning that only 5 of the 6 bolts could mount. would the tv cable and the coolant lines from the th350 cross over?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 12-08-2006, 01:32 AM   #2
Slammed70
Slammed70's Avatar
Re: 700r4 questions
The TH350 dont have a TV cable, and the cooler line fitting should be the same. Might have to do a little bending though to get them to the right area.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-08-2006, 10:22 AM   #3
woodridge
woodridge's Avatar
Re: 700r4 questions
The 350 uses a kickdown cable but has a different end where it attaches to the tranny. There is an adapter available to make it work on the 700. Cooler lines will work.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 12-08-2006, 03:50 PM   #4
brak
brak's Avatar
Re: 700r4 questions
with a 700r4, you will have to install a kit to retain 4th gear lockup, as that was controlled electronically. I prefer to use the kit from TCI (p/n 376600), it's really easy to install, and allows you to install a switch to disable lockup (like the towing feature on most new trucks) and also to lockup the tranny manually in any gear.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-08-2006, 03:54 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 700r4 questions
And as for adjusting the TV cable, the only way to do it in a nonstock aplication is with the bowtie overdrive (www.bowtieoverdrive.com) kit. Read what they have on there site, and decide for your self if it is woirth your time and money. The adjustment is VERY important.
Old 12-08-2006, 11:46 PM   #6
crm318
crm318's Avatar
Re: 700r4 questions
well what do yall think about the 5 bolt mounting situation?
1972 Cheyenne
Old 12-09-2006, 12:36 AM   #7
powell72
powell72's Avatar
Re: 700r4 questions
I certainly wouldn't worry about it, five bolts will hold it together just fine. It's a good idea to look into those tvmadeez setups from Bowtie Overdrives like Longhorn said.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 12-09-2006, 03:43 AM   #8
brak
brak's Avatar
Re: 700r4 questions
I ran a th-350 in my 81 silverado (daily driver) for two years with only 4 bolts in the tranny (lost a couple when i swapped my motor and was too lazy to replace them), until i swapped in the 700r4.
I never had a problem.
Old 12-09-2006, 04:26 AM   #9
krue
Designated A-hole!
krue's Avatar
Re: 700r4 questions
I've pulled trannies only to find 3 bolts holding them in.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-09-2006, 06:21 AM   #10
Longhorn Man
Re: 700r4 questions
Now, if you are missing a dowel... then you have problems.
Just put lock tight on the remaining bolts if it helps you sleep.
Old 12-09-2006, 01:27 PM   #11
crm318
crm318's Avatar
Re: 700r4 questions
thanks for the info guys
1972 Cheyenne
Old 12-10-2006, 12:40 AM   #12
68C15
blood type; Retumbo
68C15's Avatar
Re: 700r4 questions
just remember like Andy said. the TV adjustment is EXTREMELY critical. being off even a slight amount will result in destruction. not enough line pressure and the clutches burn up. too much and you will have a scrap metal fit.
I suggest towing it to a tranny shop for this. money well spent.
68C15 is offline   Reply With Quote
Thread Tools
Display Modes
