Old 12-17-2006, 03:02 PM   #1
BarryB
BarryB's Avatar
68 truck cab/ Patch panels.
The floor is pretty solid. slight surface rust underneath.The cab supports are in good shape. The PO had started putting in rockers (GM rockers too.) and cab corners. There is a little rust starting over the drivers side sunvisor. And some rust of the firewall. In the normal spots. I will take 150.00 for the whole cab, or we can talk about pricing for patch panels.
BarryB is offline   Reply With Quote
Old 12-20-2006, 05:45 PM   #2
BarryB
BarryB's Avatar
Re: 68 truck cab/ Patch panels.
TTT for me. Nobody interested.
Old 12-22-2006, 04:56 AM   #3
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
If u were closer i would jump all over this, What's the possibility of getting the Floor Mtgs, Rockers & corners?
Thanks, Rick
toomanytoyz is offline   Reply With Quote
Old 12-22-2006, 12:41 PM   #4
BarryB
BarryB's Avatar
Thanks, Rick
You the cab brackets that mount to the floor?? I have one cab corner off it hadn't been installed yet. Rockers might take some time to remove them from the cab. seeing the PO started installing them.
Old 12-22-2006, 11:08 PM   #5
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
I would be interested in the drivers rear cab corner.
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 12-29-2006, 08:29 PM   #6
72SWBChevy
72SWBChevy's Avatar
If you were closer..
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 12-29-2006, 08:57 PM   #7
71chevytruckguy
71chevytruckguy's Avatar
got any pics of the cab? i might be interested. thanks. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 12-29-2006, 10:28 PM   #8
BarryB
BarryB's Avatar
No but I can get some. P.M. your email addy and I'll send them to you tomorrow night.
Old 01-28-2007, 12:24 AM   #9
toomanytoyz
Luv the Crewcabs
Still have any parts from this?
Thanks, Rick
Thread Tools
Display Modes
