12-18-2006, 07:02 PM | #1 |
Help- Leaking water in passenger side floor board
Like the title says I have water coming into my cab onto my passenger floorboard. I did some water tests and it is coming in from below the windshield wiper...when water goes into the vent there. Does anyone know if there is a drainage tube that could be blocked up, or a hole that shouldn't be there? Any help would be great.
12-19-2006, 10:18 PM | #2 |
Re: Help- Leaking water in passenger side floor board
I'll bet it's a hole someone drilled for the radio coax cable. Go ahead and plug it. The water the comes in the grill/cowl opening is suppose to run to each side and down to the cowl drain opening that is inside the fender. (see red arrow)
12-20-2006, 01:35 AM | #3 |
I'll check the drain hole. As for someone drilling a hole. My truck has original am radio in it so i doubt anyone did any modifications to the firewall. I hope I can figure it out.
12-20-2006, 03:33 AM | #4 |
KEEP ON TRUCKIN'
Sonds like you might have a rust hole. Sometimes it's hard to determine where water is coming from as it will find away through the smallest of holes.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
12-20-2006, 07:08 AM | #5 |
I just fixed the same thing on my truck. Remove the cowl (5 screws and 4 bolts). Once you pull it off, chances are you will find a spot of rust below the corner of your windshield. Both sides of my truck had water coming in. I was really worried considering the volume of water coming in, but it turned out to be minor. Also, check the antenna wire. I had to reseal mine. The old sealant just was too old and not cutting it anymore. Good luck.
12-20-2006, 11:09 AM | #6 |
Future TOTM Winner
It sounds like you have ruled out a leaky heater core, but I thought I would through it out there. I agree with the others. It's most likely a small rust hole hiding under the cowl.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Thread Tools | |
Display Modes | |
