Old 12-20-2006, 03:15 PM   #1
Chris27
Blazerless
Chris27's Avatar
72 window crank help
What all do I need to change to get my stock '72 door panels to fit? a PO swapped '71 or older cut down truck doors. The shafts that the window crank and door handle go on seem too short. Do I just replace the shafts, or is it more involved? Thanks in advance.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 12-20-2006, 05:51 PM   #2
jaros44sr
jaros44sr's Avatar
Re: 72 window crank help
IIRC only '72 had longer crankhandle shafts, so if you get the right window regulator you should be good to go.
The door panels on a '72 stick out further,thus the need for longer stems.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Thread Tools
Display Modes
