12-20-2006, 07:56 PM | #1 |
I'm a poor spectator
Header RAGE!!!!
I hate headers now, plain and simple. Ordered some a while back and Summit sent me the wrong ones. No big deal, they said, just send them back. So off to FEDEX I go with a box full of bent of tubing to give back to summit. So being the great company they are, they go out of there way to look up the "right ones" and send them off to me as soon as they recieved the other ones. These so called "right ones" turn out to be the wrong ones so now I hate headers. If you've ever shopped for 4x4 4 speed headers you might understand where i'm coming from. The clutch linkage just ain't working out for me. It's close enough where I could modify it but I shouldn't have to do that. I might be off to the scrap yard real soon to pick up some manifolds but i've tried that and for some stupid moronic reason junk yards are real f*&^ing proud of them. I might take up drinking instead of trucks from now on.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
12-20-2006, 08:34 PM | #2 |
Cochino_Racing_909
Re: Header RAGE!!!!
Wow I am sorry to hear that! Well If you want you can call these guys .... Its called J & M Speed center in Riverside CA
J & M Speed Center jmspeedcenter.com 3230 Motor Cir Riverside, CA 92504 (951) 688-7110 Ask for Kyle I am sure he can get you what you need....They have never failed me! |
12-20-2006, 10:37 PM | #3 |
Location: vacaville ca, because it as far from indy as i can be
Re: Header RAGE!!!!
my hooker comps fit absolutly perfectly around my 4x4 4speed in my 77, i think they list as '63-'87.
12-21-2006, 12:21 AM | #4 |
Future TOTM Winner
Re: Header RAGE!!!!
I'll trade you my manifolds for your perfect sheet metal!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
12-21-2006, 01:25 AM | #5 |
Re: Header RAGE!!!!
You can go to the local parts store and get new rams horn manifolds. Why pay a junk yard for old ones that probably have cracks in them. Just my opinion.
12-21-2006, 04:03 AM | #6 | |
Active Member
Re: Header RAGE!!!!
This is why i am going to put in a hydraulic clutch setup from an 86 chevy pickup. I already have the bellhousing, so i might as well.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
12-21-2006, 10:45 AM | #7 |
Re: Header RAGE!!!!
I assume you have a 350SBC.
Here is a pic of my old 350 with Hedmen Elite series coated headers: You can see the bracket that holds the frame side of the Z-bar. I relocated the mount hole just 1" over and they clear just fine. I had a set of Hedmen (cheaper version) first and they ended up warping after 4yrs so I got the Elite series cuz they had super thick flanges and don't warp like the cheeper versions do. Now with the 454BBC I installed, I swaped out the manual linkage for hydro setup wich made the install WAY easier and realy the only way to get Thorleys to work on a BBC... You can see the slave cylinder mounted to my cast bellhousing. I removed the frame bracket too as it is no longer needed. here is the bracket I used to mount the slave to my old cast bell housing: So if you decide to go Hydro you don't have to switch the bell housing to the weaker alluminum one that GM uses for Hydro... Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
12-21-2006, 02:06 PM | #8 |
Re: Header RAGE!!!!
i know how that is i got a new set of block huggers that wont clear my crossmember so i am going to be looking for some new ones soon and trying to sell these old ones to some hot rodder cause i dont have the slighest idea of what they will fit thee supose to fit any pre FI small block
http://www.cardomain.com/ride/2461088 |
12-21-2006, 03:28 PM | #9 |
The LuvShack Garage
Re: Header RAGE!!!!
I have these headers on "GQ" not a 4 speed, but NO clearance issues
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
12-21-2006, 04:55 PM | #10 |
Sofa King. We, Todd, Ed.
Re: Header RAGE!!!!
Sounds like your problem is with SUMMIT. As the manager of a local speed shop I'm always a little confused as to why people will support the big mail-order companies rather than thier local businesses just to save a few bucks. Now, if you dont have a good local speed shop, then I understand. ALSO, one more thing. If you plan on driving thru lots of mud I wouldnt bother investing in expensive ceramic coated headers...they will just turn a nice shade of light brown.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon Last edited by johnnywagon; 12-21-2006 at 04:59 PM. |
12-21-2006, 07:32 PM | #11 |
Re: Header RAGE!!!!
It smells like jealousy in here. I looked up the hooker headers and it looks they will be the best fit but I still haven't decided on whether or not i'll look into some manifolds or not. I don't even care right now, i'll have more time to worry about it after Christmas.
12-21-2006, 09:24 PM | #12 | |
Active Member
Re: Header RAGE!!!!
Where did you get the slave cylinder or who makes it. I may just go that way instead. Need to get rid of my worn out clutch linkage somehow anyway.
12-21-2006, 11:00 PM | #13 | |
Future TOTM Winner
Re: Header RAGE!!!!
12-22-2006, 10:54 AM | #14 |
Re: Header RAGE!!!!
The slave cylinder is from a 80s Toyota Land Cruzer. The mounting bracket is made by thease guys:
http://www.advanceadapters.com/ They make it mainly for thoes guys that put Chevy drivetrains in a Land Cruzers... So far this setup has worked verywell.... Happy Holidays Burt PS nice green and red fourm egh?
12-23-2006, 01:33 AM | #15 | |
Active Member
Re: Header RAGE!!!!
Thanks for the info.
Thread Tools | |
Display Modes | |
