Old 12-24-2006, 06:37 PM   #1
my67C10
my67C10's Avatar
spot welds on the bedsides
i was able to get drill out the spot welds around the wheel wale and along the stake pocket (red arrow's) the skins are now only connected at the top of the bedside (blue arrow's) i cant find any spot welds on the top of the bedsied, can somebody please shed some light on the subject.
Casey
my67C10 is offline   Reply With Quote
Old 12-24-2006, 07:03 PM   #2
Sweet72
Sweet72's Avatar
Re: spot welds on the bedsides
Are you reskinning the whole bedside?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-24-2006, 07:12 PM   #3
bowtiehotrodder
SIX BANGER
bowtiehotrodder's Avatar
explan what you are doing. if you are reskining the bed side only. the welds will be on the lip that turn down towards the bed. ___
http://www.cardomain.com/ride/2597018(NN)
1979 chevy truck swb 454 w turbo400 with buckets
1977 chevy truck swb soon to be 454
1976 chevy dually 454
1969 chevy truck six shooter
bowtiehotrodder is offline   Reply With Quote
Old 12-24-2006, 07:23 PM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
What he said...They are easier to find if you do a little sanding first. Drill them out and voila, 2 pieces. Getting it back together is a #$@!^%$ by the way. Ask me how I know...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-24-2006, 08:55 PM   #5
bowtiehotrodder
SIX BANGER
they are not on top where you got the blue arrows they are on the small lip that turns down towards the bed floor
Old 12-24-2006, 09:33 PM   #6
matthufham
easier shown then said
matthufham is offline   Reply With Quote
Old 12-25-2006, 12:59 AM   #7
my67C10
my67C10's Avatar
sweet!! im taking the skins apart so i can get some dents out (i dont have enought money to get new skins).
Old 12-25-2006, 01:06 AM   #8
layedoutnoma
layedoutnoma's Avatar
http://www.eastwoodco.com/shopping/p...ProductID=1753
would save you a ton of work
Meticulous Fabrications
Milford Michigan
layedoutnoma is offline   Reply With Quote
Old 12-25-2006, 08:29 AM   #9
Aarons72s
My67c10 there are also spot welds behind the cab where the inner and outter skins meet. If you wait a couple of days I can get you pics of my bed skin that I removed and it will show where all the spot welds are. Plus the stake pockets are supposed to stay with the inner box not the outter. The outter is held on in the rear with spot welds along the edge next to where the tail light holes are. Hope this helps. If you want the pics please pm me and I will go get them for you.
Aarons72s is offline   Reply With Quote
Old 03-26-2007, 07:29 PM   #10
Aarons72s
Im sorry I completely forgot. But here are those pics for you. The red dots represent the spot welds. There spacing and quantitry varies from bed side to bed side but they will give you an idea. I would drill out the inner spot welds when seprating the skin at the front behind the cab as since it is flat metal and will also brace the side to keep it from warping. I also marked where the spot welds are around the tailight housing. They are harder to spot but they are there. Hope the pics help. Sorry I forgot about the pics for so long.
Old 03-26-2007, 07:39 PM   #11
arkracing
Weekend Warrior
I Could be wrong but I think the spot welds on the back of the panel near the taillight are around the corner facing the tailgate.
Do you plan to weld these back on the truck? - you might want to check out using "glue" like a 3M Panel Bonding Adhesive or SEM etc. - Eliminates water getting between the two layers of steel - really good idea around the wheel well.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-27-2007, 10:54 AM   #12
daryn_24
Buy a unit-spotter, and you won't have to pull the skins off to take the dents out!!
daryn_24 is offline   Reply With Quote
Old 04-11-2007, 01:30 PM   #13
my67C10
my67C10's Avatar
well the truck isnt smashed in but they arent small dents, the skins would need to be seperated to hammer them out. thanks agian for the help guys
Thread Tools
Display Modes
