Old 04-24-2002, 04:37 PM   #1
Billy Porter
Post Urgent... How to remove entire dash assembly?
Since my truck was vandalized and the assembly was banged up, how difficult is it to replace the entire thing.... I noticed that the steering wheel and stuff have to be droppped. And ther are 3 bolts on each side in the corners.... what else is holding it in place? the speaker bracket etc or what
71 GMC Stepside
250/350 Turbo better known as "Fred Sanford
77 240 Mercedes Benz
92 300E Mercedes Benz
85 600 Ninja
71 Chevelle
71 GMC Stepside
70 Firebird 400
85 600 Ninja
Billy Porter is offline   Reply With Quote
Old 04-24-2002, 04:53 PM   #2
fine69
fine69's Avatar
Post
Ok. The "proper" way to remove it would be to remove the windsheild,drill the spotwelds out,hack,beat,cuss,throw stuff. And hope it comes out.
Now to reality. I just removed a complete dash assy. to put it into my 70 panel. Which was hacked to hell. I took all the side bolts out. Took the dashpad off, used a sawzall to cut the dash under where the pad is. It gets a little tricky near the corners. But i used a sharpened putty knife as a chisel at the corners. It worked out ok. You can put it in, match up the cut lines, tach weld it back. You will need to do a little bodywork at the corners. But it aint too bad. A little work at the top corners will not be near as hard to make look good as work in the center of the dash.
A plazma cutter would work good also if you have one.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 04-24-2002, 04:54 PM   #3
SCOTI
SCOTI's Avatar
Post
Although I've personally never removed one, the spot welds all the way across the lower windshield/dash lip have to be drilled out before it can be removed from what I can tell on the stripped cab in my driveway.
[This message has been edited by SCOTI (edited April 24, 2002).]
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-24-2002, 05:54 PM   #4
GMT830
Post
Depending on how bad the damage was you might try stripping all the gages bezels and trim from it and having a body man work out the damage. It might save you a lot of frustration.
The puppy barks but the truck rolls along
GMT830 is offline   Reply With Quote
Old 04-24-2002, 08:26 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
The cool thing about fine69's way, id the dash pad will cover all traces of the work being done. Many have done it this way.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-24-2002, 09:05 PM   #6
JoetheMobster
Listening since '86
JoetheMobster's Avatar
Post
Kind of makes you wonder what the hell the people that made these trucks were thinking when they decided to WELD in the dashes!! On my little piece of crap car, I can take the complete dash out in no time! (and NO not with a BFH!!)
1970 GMC 1500, 350ci, 3 in a tree
http://members.tripod.com/~Jungleman_2/1970GMC.html
Vancouver, B.C.
2007 Saturn Aura - hey it WAS a GM product
JoetheMobster is offline   Reply With Quote
Old 04-24-2002, 09:11 PM   #7
Longhorn Man
Post
Joe, you shouldn't call your 70 GMC a little piece of crap!!!
Thread Tools
Display Modes
